Author Topic: 997 feezing up  (Read 5189 times)
Offline satdoc1
  • Unit(s): 997
  • Software: just updated ?
997 feezing up
« on: March 20, 2011, 06:51:29 PM »
Anyone having a problem with the 997 freezing up and not working?  Unplug it and it will work for a while and freeze up again.
satdoc1doc1
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: 997 feezing up
« Reply #1 on: March 20, 2011, 11:47:45 PM »
Where are we talking in your house out on the lake or what ? Must be in your
 house if you are unplugging it. I would look for a power issue.
Offline satdoc1
  • Unit(s): 997
Re: 997 feezing up
« Reply #2 on: March 21, 2011, 02:17:25 PM »
The unit is in the boat, I can unplug it by taking the connector off the bck of theunit like I always do to store it.
satdoc1doc1
Offline lcookie
  • Unit(s): 998SI/1198SI/788DI/587DI
  • Software: 6.68/6.64/6.64/6.09
  • Accessories: Ethernet, GRHA, ASGPSHS,WeatherSense
Re: 997 feezing up
« Reply #3 on: March 21, 2011, 02:25:16 PM »
I too had this problem.  Check your power wires all the way back to the battery.  To fix my problem I ran new wires from the battery to the console just for the unit.  The stock wires were too small.
Re: 997 feezing up
« Reply #4 on: March 21, 2011, 07:37:09 PM »
Power wire size is everything.  What size wire are you using to supply the HB????
Offline satdoc1
  • Unit(s): 997
Re: 997 feezing up
« Reply #5 on: March 22, 2011, 10:18:56 AM »
Have it plugged into the fuse block of the boat. Have had it hooked there for a year with no problem till now
satdoc1doc1
Re: 997 feezing up
« Reply #6 on: March 22, 2011, 10:29:06 AM »
OK, but not to say the connection has changed. Loosened up, corroded or fraying.  Just requesting that you recheck the electrical connection(s).
You might check the plug at the back, removing and reconnecting over time can loosen the plug pins.
There is a hint to slightly bend the male connectors so as to increase the connection pressure on the unit plug cable.
« Last Edit: March 22, 2011, 10:31:12 AM by sonar2000 »
Offline satdoc1
  • Unit(s): 997
Re: 997 feezing up
« Reply #7 on: March 22, 2011, 05:10:17 PM »
Just ran new 16 ga wire from batterey to unit , seems to be running ok will laet it run for a while to see if it locke up again. Thanks for the help.....
satdoc1doc1
Re: 997 feezing up
« Reply #8 on: March 22, 2011, 05:23:23 PM »
If you use anything else than 16 guage then it may cause problems depending on the length. For electronics We use 16 guage and for motors I may go as high as 12 guage and this is hard copper.
If it is 24 volts we may go to 10 guage.
Generally we stay away from stranded wire.
And also aluminum wire is a nono..
Offline satdoc1
  • Unit(s): 997
Re: 997 feezing up
« Reply #9 on: March 22, 2011, 07:08:00 PM »
Use 16 ga wire only around 8 ft from battery to 997.  Unit has been running for almost 2.5 hrs without freezeup. May have problem solved.
satdoc1doc1
Re: 997 feezing up
« Reply #10 on: March 22, 2011, 07:09:46 PM »
What size wire was there originally?  Was it hard or stranded..?
Glad you are back in business.
