Author Topic: images are not clear  (Read 6817 times)
Offline whlsup
  • Unit(s): 987c si and 997c si
  • Software: 4.770 and 4.950
  • Accessories: weather sense two, one yellow one black
« on: March 12, 2011, 11:16:30 PM »
I have two units, a 987 on the bow very clear images and no problems, connected to the 997 console unit via interlink, both units are on 4.995 to correct interlink problems. the console unit has unclear images. the engine off, and varied the settings even did a restore. still the same. any ideas?ila_renderedila_rendered
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: images are not clear
« Reply #1 on: March 13, 2011, 07:32:58 AM »
Whlsup I would change the heads around and see what happens it might be a transducer since you
have your motor off. I would make sure everything in the boat is off except the unit in question
I would run a dedicated power supply wire straight to the starting battery.  Gary
« Reply #2 on: March 13, 2011, 10:00:20 PM »
Well first off that green is a horrible color for SI! ;D
Looks like you may have some interference going on.
Offline whlsup
« Reply #3 on: March 17, 2011, 07:38:36 PM »
I have tried to swap the heads between front and back, the white specs follow the 997 even when changing the color to Blue. The white specs track along with the graph.
Offline stillbear
  • Stillbear
« Reply #4 on: March 18, 2011, 07:29:26 AM »
Unhook your interlink just run the 997 buy itself. Interference should go away. Gary
Last post March 30, 2012, 12:22:44 PM
by johng789
Last post June 06, 2013, 08:46:26 AM
Last post October 29, 2013, 12:49:15 PM
by JDX
Last post January 14, 2014, 11:23:18 AM
by Rotus623
Last post April 15, 2014, 06:37:33 AM
by slabbacks
Last post June 23, 2014, 12:13:59 AM
by reefmo
Last post June 04, 2014, 09:57:34 AM
Last post October 28, 2014, 12:35:46 AM
by Cacciatore
