Author Topic: Re: New SI trandcuer for 1197  (Read 6283 times)
Offline ben2kona
  • Unit(s): 1197 SI Combo dash, 1197 SI Combo Bow
« on: February 26, 2011, 03:42:28 PM »
I just go on the water for the first time this year. My SI transduer mounted on my trolling motor shows significant noise in the image (screen) when the trolling motor is running. I can't believe this is normal. The side imaging and down imaging go virtually white with noise and the regular 2D sonar in not affected too bad, but some noise also. Can any help me understand if this is normal or is there something wrong with my transducer. Both the trolling motor (Minn Kota Fortrex) and 1197SQ unit are brand new.
« Reply #1 on: February 28, 2011, 03:43:39 PM »
What you are seeing is RF interference from your trolling motor.  It is quite normal for today’s trolling motors to produce RF energy due to their PWM (Pulse Width Modulation) circuitry that they use to control the speed of the motor.
I would start by checking the internal ground wire on your trolling motor is it has the built-in universal sonar transducer (US2).
Next I would check the transducer cable for the transducer model number.  Post back all the numbers and letters that you find as these will be within the first few feet of the connector end of the cable.
« Reply #2 on: February 28, 2011, 05:06:33 PM »
Greg, what will those numbers mean to us?
chuck
« Reply #3 on: February 28, 2011, 05:10:02 PM »
Chuck it would mean whether he has an older HDSi transducer that does not have the additional copper shielding inside of it or the newer one.  If it is the older one than installing a newer one could possibly help.
[Speaking of Weather… the Tornado warning is over and it looks to be clearing up so I’m outa here!]
« Reply #4 on: February 28, 2011, 05:13:31 PM »
Yep you are sending the tornado toward us.  thanks.... ;D
Does testing take into consideration the different transducers or do they just test the latest?
Just asking in case we need to make a list for questions when the guys start asking...
« Last Edit: February 28, 2011, 05:20:13 PM by sonar2000 »
« Reply #5 on: February 28, 2011, 05:16:10 PM »
Latest only Chuck.
« Reply #6 on: February 28, 2011, 05:21:48 PM »
OK. might be a clue to look at..
Last post April 14, 2010, 03:44:38 AM
by bistatecats
Last post August 30, 2009, 03:19:02 PM
by keizerh
Last post January 08, 2010, 10:05:34 AM
Last post April 29, 2010, 03:38:23 PM
by keizerh
Last post March 24, 2010, 01:34:54 PM
Last post April 05, 2010, 10:51:49 PM
by mendota
Last post February 02, 2011, 05:30:18 PM
by tnsuperpro
Last post February 03, 2011, 01:05:14 PM
