Author Topic: Issue with 5.32 update  (Read 20822 times)
IRC Kevin
  • Guest
« on: February 13, 2011, 11:07:23 AM »
Updated yesterday, taking care to return to defaults beforehand. Everything works fine except for down imaging. It works okay in split screen views, but when I select it on its own, the screen just flashes betyween blank and the next screen option. Anyone else had this problem?
Re: Issue with 5.32 update
« Reply #1 on: February 13, 2011, 12:01:41 PM »
Kev, I installed the update last week and ran some scans.  It works fine for us.  did not have the problem you describe.  in fact it worked fine.  dont know buddy.  you might try a re-install
chuck
IRC Kevin
  • Guest
« Reply #2 on: February 13, 2011, 01:43:14 PM »
Can I re-install from the SD card, or do I need to connect to a computer? If the latter, it will have to wait until the next update, as I don't have the lead.
« Reply #3 on: February 13, 2011, 05:08:33 PM »
Kevin, I would delete the current file and download again.  sometimes the files just dont come across as they should.  Not sure why that is.
I have seen where the download seems to go  ok but problems after installing.  I would try the download again.
Installing from the card should be fine and I would hold off on the cable and doing the install from the HBPC program for a bit.
Try the re-install and lets see what happens...
« Reply #4 on: February 13, 2011, 07:15:41 PM »
Kevin,
You will need to delete the current file off the Sd card, and put the previous update on there.  Do a normal software update with the old file.  Then, delete that file off the SD card and put the new one back on and do the update again.
Make sure to follow the proceedures step by step.
Good Luck,
IRC Kevin
  • Guest
« Reply #5 on: February 14, 2011, 02:21:16 PM »
Thanks, Guys. I'll try that next time I go up to the boat.
regards,
Kevin
IRC Kevin
  • Guest
« Reply #6 on: February 21, 2011, 08:15:11 AM »
Followed your advice and everything working well now. Many thanks.
IRC Kevin
  • Guest
« Reply #7 on: February 21, 2011, 11:33:08 AM »
Reset my defaults and problem back again! Went back to manufacturer's defaults and all okay. Turns out that the issue re-occurs when I set either (or both) Si and Di sensitivity to 'auto'. System fine when they are adjusted manually. This must be software glitch.
« Reply #8 on: February 23, 2011, 04:01:19 PM »
Anyone else see this on their unit?
Offline reddog
    • My pictures
  • Accessories: Ipilot Link
« Reply #9 on: February 23, 2011, 04:11:11 PM »
I dont remember having this issue, but I can almost guarantee I didnt try DI only.
Il hook up myunit when I get home tonight and let you know.
Im assuming since the boat is not in the water, that the DI view should at least come up, even if it doesnt show anything on it, assuming I hook up the xducer and gps module as if it were in the water.
« Reply #10 on: February 23, 2011, 05:10:23 PM »
I do not see this on the 1197 with 5.3......chuck
Offline charilaos1
  • Unit(s): 997csi
  • Software: 6-300
« Reply #11 on: February 24, 2011, 10:22:11 AM »
i have the same issue ! my unit is 997. this must be software glitch.
IRC Kevin
  • Guest
« Reply #12 on: February 24, 2011, 11:19:09 AM »
Glad it's not just me- not a quick or easy process sending a faulty unit back from the UK.
Offline jgollihar
  • Unit(s): 1197, 998
  • Accessories: interlink
« Reply #13 on: March 06, 2011, 03:22:18 PM »
Having the same problem with my 1197 and 998. Problem only occurs when the sensitivities for the down and side imaging are set to AUTO.
Has to be a glitch in the update.
Offline Hollywood
  • Unit(s): 898c SI & 565
  • Software: 5.410
  • Accessories: Weather Sense
« Reply #14 on: March 06, 2011, 05:21:48 PM »
I bought my 898cSI last spring and just did the update (5.410) and had the same problems that you guys mentioned with the update. I did the change from auto and bam it was fixed. My full screen down scan also dissappeared also but reappeared after I changed from the auto position to one up. I always visit this site but never joined. I did now because of this fix you guys figured out. Thanks a lot! I still need some help but that's for another day.
« Reply #15 on: March 06, 2011, 05:39:28 PM »
Our 1197 was made in 2009.  It does not have the above problems.  Wonder if this is something in the internal software (for newer units) and brought on by the changes in the 5.3........
Any one else with a 2009 or older having these problems.
I thought about this some more.
We dont see any of the reported problems that have occured over the last year of posts.
Makes me wonder about 2010 and above mfgd units and the operating code within.
« Last Edit: March 06, 2011, 05:57:41 PM by sonar2000 »
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #16 on: March 07, 2011, 06:22:00 AM »
Yes my 997 is doing the same thing sens. in auto messes everything up take it out of auto
everything fine. I have not checked my 1198 yet.   Gary
Last post November 20, 2009, 09:37:27 PM
by harry padgett
Last post March 11, 2011, 08:37:06 AM
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post April 15, 2014, 05:25:41 AM
by Skot
Last post July 08, 2014, 01:05:24 PM
by Bobbylove
Last post March 09, 2015, 12:00:19 PM
by navionic
Last post April 10, 2015, 03:13:05 PM
by 4d-rock
Last post June 17, 2015, 09:35:01 PM
