Author Topic: What changes were included in software version 5.320?  (Read 12740 times)
Offline Trytoofish
  • Software: 2.0, 7.51,
« on: February 08, 2011, 05:48:20 PM »
If you have a:
    * 1197C SI
    * 997C SI
      5.320 includes:
The new Contour Mode has been added.  This Mode is part of the SI Enhance Menu in the Express Sonar Menu.
Contour Off shows you the standard Side Imaging view
Contour On removes the water column and shows you a flat representation of the bottom.
Addition of Side Imaging range lines
Side Imaging Navigation - When you are Navigating (GOTO) to a waypoint the boat icon on the top of the side imaging screen will try to show you the direction to the waypoint. This icon will move around to provide the direction to the waypoint.
Addition of Down Imaging™ Zoom
 plus a fix relating to DownImaging bottom lock, DownImaging shallow water depth detection, DownImaging sonar recording/playback at shallow depths
      If you have a:
    * 1197C SI
    * 997C SI
    * 957C
      5.320 includes:
      Resolution to Interlink issues affecting GPS connectivity and waypoint sharing, along with changes to:  importing from an MMC card, setup menu options, exit during remote sync in progress, GPS Course and auxillary temp alarm.  Both units connected through the Interlink must have 5.210 software or higher loaded onto their units for these changes to work.
      Chart layers were added, custom chart menu display was fixed along with minor Downrigger fixes were made for those with Cannonlink.
      If you have a:
    * 1197C SI
      The Auxillary Temperature information box was added.
« Last Edit: February 08, 2011, 07:06:02 PM by RGecy »
Try Too Fish  Forced To Work
Re: What changes were included in software version 5.320?
« Reply #1 on: February 08, 2011, 07:07:41 PM »
Trytoofish,
Thanks for posting the information from the Humminbird FAQ section.
I have edited and attached the images and video here for everyone to see.
How To Change Your SI Unit To Contour View.MP4
« Last Edit: February 08, 2011, 07:21:03 PM by RGecy »
Offline Trytoofish
« Reply #2 on: February 08, 2011, 07:32:54 PM »
Thanks Robert
Much better,I hoped the images would copy/paste but no such luck.
 also I could not get the video link in the FAQ to work. Is that where you got it.
« Last Edit: February 08, 2011, 07:35:00 PM by Trytoofish »
« Reply #3 on: February 08, 2011, 09:32:20 PM »
No, the link for the video was not correct.  The video was also on youtube.
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« Reply #4 on: February 08, 2011, 11:03:07 PM »
Why did they not add the 898 unit as well for the folks that have those.  I thought the compueter ships in the 898, 997 and 1197 were basically the same...or that is what we were told last year in a seminar hosted by a Humminbird tech.  Also, i do realize the 898 and 997 have the same pixels with the 1197 being different...is that correct ?
« Reply #5 on: February 09, 2011, 03:30:28 AM »
calli,
I posted a detailed response in your other post.  Short and simple, no they are not the same.  Each unit has slight differences that make it necessary to have different updates.  Especially in the new models vs old models.  They actually changed the OS software in the new models.
http://forums.sideimagingsoft.com/index.php?topic=2090.msg11444#msg11444
Good Luck,
« Last Edit: February 09, 2011, 03:32:03 AM by RGecy »
Offline Irishrover
  • Unit(s): 997c SI Combo NVB and 898C SI Combo
  • Software: Navionics NVB
  • Accessories: Lakemaster Pro Map Wisconsin
« Reply #6 on: March 02, 2011, 01:59:49 AM »
Trytoofish, I have a 997c SI Combo on the console & on the trolling motor I have a 798CI. They're both hooked into each other w/Interlink. Now when you posted that both units must have the 5.210 updated version for the Interlink to work properly...I went online to Humminbird to view my profile...the 997 update available is the 5.320 version & the 798 update available is the 5.210 version. So are you just saying that both units have to have at least the 5.210 or higher versions for the Interlink to work correctly? Thanks for all of your help
« Reply #7 on: March 03, 2011, 02:53:25 PM »
Irishrover,
For the InterLink to work, both units would need to be running software that is version:
4.995 or lower
5.210 of higher.
But the 5.210 software (and higher version numbers as of today) has not always worked either… So I would contact the Humminbird Customer folks and ask for the 4.995 software for each of your units until they can come out with a newer version of software that works better with the InterLink.
Offline Trytoofish
« Reply #8 on: March 03, 2011, 03:08:26 PM »
Irishrover
you should be able to get the older versions here
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=1
Last post February 01, 2013, 04:23:48 PM
by Jim Jack
Last post January 31, 2015, 12:55:13 PM
Last post January 19, 2015, 04:53:02 AM
by sfw1960
Last post December 17, 2015, 04:03:34 PM
by Beaulieu80
Last post December 26, 2016, 07:34:48 PM
Last post April 02, 2017, 10:29:05 PM
Last post April 26, 2019, 11:49:40 PM
Last post July 28, 2022, 03:46:11 PM
by Davide
