Author Topic: Reseting Defaults HELP!  (Read 9380 times)
Offline cwarner
« on: January 21, 2011, 07:32:56 PM »
Can anyone tell me what will happen if you don't reset your defaults before downloading a new software version? It was my first download...got in a hurry and didn't reset defaults, now I am worried!
« Last Edit: January 21, 2011, 07:37:03 PM by cwarner »
Offline offroad
  • Unit(s): 1197/ 898
Re: Reseting Defaults HELP!
« Reply #1 on: January 21, 2011, 07:47:48 PM »
So what was the result ? is the unit working as it should !
Offline cwarner
« Reply #2 on: January 21, 2011, 07:53:20 PM »
The new version downloaded fine. The unit seems to work....I haven't got to use it yet. What problems occur when you do not restore defaults?
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #3 on: January 21, 2011, 08:14:55 PM »
cwarner the unit will let you know if the update is wrong. Depth readings
could be off whatever the update was for won't work. Then again you might luck out
and everything works good even though you did not reset factory defaults before and
after your update. I would not worry either way because you can always update it again
just takes time.   Gary
Offline cwarner
« Reply #4 on: January 21, 2011, 08:24:39 PM »
Thanks for you input!
Wayne P.
  • Guest
« Reply #5 on: January 21, 2011, 09:04:03 PM »
Part of the software is a automatic default setting before starting the new upload.
That was stated with one of the software releases last year.
If some stuff acts strange, do a post upload default setting so the unit will forget about the upload.
« Reply #6 on: January 22, 2011, 12:15:37 PM »
It all depends on what level of software you had in your unit before you updated it.  If it had new enough software than the unit automatically reset the menus to the defaults as Wayne stated.  But, if the unit is working fine now than no worries!
Last post October 15, 2009, 01:23:42 PM
Last post August 16, 2011, 09:43:23 AM
Last post October 31, 2013, 07:44:57 PM
by geemul
Last post June 03, 2012, 10:19:55 AM
by Blackwaterkatz
Last post June 17, 2015, 06:34:17 PM
Last post March 03, 2018, 09:19:45 AM
Last post July 22, 2018, 11:27:13 AM
by hollada
Last post November 17, 2018, 07:50:03 PM
