Author Topic: setting while mounted on trolling motor?  (Read 7379 times)
Offline DitchPickler
« on: January 20, 2011, 08:27:13 PM »
what are the best settings for SI when the transducer is mounted on the trolling motor? Since the trolling motor goes 360.  i plan on split screening it 3 ways....using SI/DI and standard sonar.
Re: setting while mounted on trolling motor?
« Reply #1 on: January 21, 2011, 03:04:21 AM »
DitchPickler,
Welcome to the forum.  The settings are pretty much going to be the same for everything even when mounted on the trolling motor.  You will just have to adjust your chart speed down to around 1 or 2.  You basically want to try to match you boat speed and chart speed.
It will be hard to maintain good SI images when turning and you will probably be using the 2d and DI more so while fishing.
« Last Edit: January 21, 2011, 03:05:59 AM by RGecy »
Offline offroad
  • Unit(s): 1197/ 898
« Reply #2 on: January 21, 2011, 02:41:20 PM »
DitchPickler,
l have my 898 on my TM .And as Robert said chart speed down to match the boat speed. l just use one side {Bank side } because thats the side that l am fishing
« Reply #3 on: January 21, 2011, 08:28:52 PM »
Great info fellas! I figured DI would be best with a slower chart speed. Never thought about using only one side SI. Makes alot of sense though. I'll be fishing 40+ ft of water for smallies out in the open. So there wont be any banks close by. But ill fiddle with the settings and report back with what worked best. Thanks for the tips!
Ditch Pickler
Last post August 28, 2009, 08:20:25 AM
Last post October 23, 2009, 10:33:41 AM
Trolling Motor Choke
Started by Wayne P. Accessories
Last post August 23, 2010, 04:47:34 PM
Last post May 25, 2010, 08:00:00 PM
by Jason Hoerter
Last post September 07, 2010, 09:32:38 PM
Last post March 18, 2011, 06:27:53 AM
by SaminVa.
Last post February 29, 2012, 01:26:51 PM
by Double Digit
Last post June 09, 2015, 02:23:49 AM
by Stano
