Author Topic: 898 pics  (Read 11963 times)
Offline dawg1419
  • Unit(s): 898
  • Software: 5.210
  • Accessories: none yet
898 pics
« on: January 17, 2011, 07:15:35 PM »
Got out today to place some christmas trees. Some of these trees are 8ft tall and they look so small on SI but the shadows tell the real story. I just have a problem seeing everything in great detail. I have my sensitivity up around 14-18 just to make my screen bright enough to see. What would help me see better detail and make the baitfish and fish pop. I got a 898 with the new 5.2 and you can take away the middle and see whats under the transducer.( i think)ila_renderedila_rendered
« Last Edit: January 17, 2011, 08:12:24 PM by dawg1419 »
Re: 898 pics
« Reply #1 on: January 17, 2011, 07:43:03 PM »
Switch it over to 800khz and bring your range down to around 40-45' and you should get some pretty good images.
If you made a recording, try playing it back and messing around the enhanced Settings.
Hope that helps.
Wayne P.
  • Guest
Re: 898 pics
« Reply #2 on: January 17, 2011, 08:06:07 PM »
To get the best images, your boat speed should be as slow are you can go and use a scroll speed close to the boat speed. The longer the beam is on an object, the sharper the image will be. Also if you what to stretch an object so it will look bigger, you can set the scroll speed a little higher.
Set the side range to around 3 times the depth to get a larger image of objects.
To make fish "pop" use the Enhance and set the Sharpness to low or medium. That will make other stuff look grainy but is best for fish.
Look at this post about that setting:
http://www.bbcboards.net/zerothread?id=530623
Offline dawg1419
  • Unit(s): 898
  • Software: 5.210
Re: 898 pics
« Reply #3 on: January 17, 2011, 08:07:53 PM »
will do robert.Thanks for the info
Offline dawg1419
  • Unit(s): 898
  • Software: 5.210
Re: 898 pics
« Reply #4 on: January 17, 2011, 08:11:52 PM »
Thanks Wayne I was hoping you would comment. I have the scroll speed down 1 lower than boat speed most of the time. Just read over on the other site about Si Enhance now I gotta go back to the lake  :P LOL
Re: 898 pics
« Reply #5 on: January 17, 2011, 09:16:00 PM »
dawg1419,
Here is some interesting reading here in the FAQ section.
http://forums.sideimagingsoft.com/index.php?topic=333.0
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: 898 pics
« Reply #6 on: January 18, 2011, 05:44:13 AM »
dawg1419 After you get your settings set and object marked make passes over object at different
angles and record them. Play back with humviewer or yellow fin you will see a difference
in appearence of the object at different angles.   Gary
« Last Edit: January 18, 2011, 05:45:56 AM by stillbear »
Last post November 25, 2012, 12:41:58 PM
by Speedtroller
Last post June 16, 2012, 07:20:49 AM
by JudoJeff1234
Last post October 15, 2012, 04:21:15 PM
Last post February 11, 2013, 10:23:16 PM
Last post March 02, 2013, 07:04:09 PM
by al49
Last post November 24, 2013, 11:15:38 AM
by Flyjunkie
Last post April 03, 2014, 10:44:27 AM
by jesse1378
Last post May 19, 2015, 09:51:12 PM
by RonnieB
