Author Topic: Membership map location  (Read 6413 times)
« on: December 24, 2010, 10:22:55 AM »
Reference the topic "new Problem":
Sharing your home location is somewhat of a privacy issue with some people and I can understand the need to protect that concern.
However we should look at this forum as a helping hand and informatin sharing to assist those who are new or experiencing unresolved problems.
I posted before to the SAR members to add location to their profile so that when  assistance was needed in a pending search we could find our closest member who  might be able to help.  I extended that in general to all members because some search assistance could be performed by any sonar user and make the recordings for the management team to view specifically.
As with Terry's need and several other users over the year, we could all benefit with a neighbors help, if we knew who that neighbor was. Being able to swap components may make the isolation of problem shorter. And save time sending the whole unit back to HB for problem determination. Especially if the problem is intermittent.
So I again ask members to check their profile and offer their location or map placement.
Thanks to all for the help you show to others in need on this forum
Chuck (sonar2000)
Re: Membership map location
« Reply #1 on: December 24, 2010, 10:53:29 AM »
Adding to  my initial post.
There are two options to indicate your location.
One is the map pin placement and the other is the profile entry location.
Some have choosen to put their unit type in the location field. Reminder that that is already a selection in your profile.
Share with us that which you are comfortable with.
chuck
« Last Edit: December 24, 2010, 10:56:16 AM by sonar2000 »
Offline terry0540
  • Unit(s): 798ci SI NVB
  • Software: 4.780
  • Accessories: none
« Reply #2 on: December 24, 2010, 11:38:11 AM »
sonar2000
As for location a "ZIP" code I think would be good enough
to find HELP for any type of problems we might encounter.
Unit problems or help with search as you indicated.
Also I hope that I met and made a new friend today
Terry
« Reply #3 on: December 24, 2010, 01:17:57 PM »
Terry, that is a good idea to put Zip in the location. For privacy purposes that is less intrusive and more geographical but will be great for help needs.
Thanks for the suggestion and the contribution to the forum.
Last post November 13, 2011, 04:21:02 PM
Last post February 26, 2012, 08:39:13 AM
by Blackwaterkatz
Last post August 19, 2012, 12:28:02 AM
Last post January 31, 2013, 11:58:16 AM
by TroyBoy30
Last post April 24, 2013, 07:28:44 PM
by hannibal mike
Last post May 01, 2013, 07:31:31 AM
Last post March 28, 2014, 07:12:18 PM
Last post January 12, 2019, 10:24:24 PM
