Author Topic: Built-in UniMap - what does that mean?  (Read 13845 times)
Offline CHOOhonets
  • Unit(s): 998 HD SI
  • Software: 6.49
  • Accessories: AS SI LR Y cable
« on: November 23, 2010, 11:50:12 AM »
What does built-in UniMap mean? I've read it in this description:
http://www.threeriversmarine.net/1197csicombo.aspx
Can i still use Navionics SD card with the region I need (38XG) with such a 1197?
PS I can also see different information about GPS - most sources say that it is 50 channel, but some say that it is 16 channel. Where the truth is at?:)
Re: Built-in UniMap - what does that mean?
« Reply #1 on: November 23, 2010, 04:30:55 PM »
The UniMap is a built in low resolution map of the U.S. (in Domestic units) and other maps in the other various International units that we build.
I believe that the 1197 units that we have been building since January 2010 all have the ContourXD maps in the U.S. version units.  These are maps with some additional detail like depth contour lines on many of the lakes.
Yes you can still use a Navionics SD card regardless of which map set is installed in the unit.  I don’t know what a 38XG card is but you can consult the Navionics web site to see if it is compatible or not.
All of the 1197 units we have built were shipped out with the GR50 50 channel GPS Receivers.
Offline CHOOhonets
  • Software: 6.49
« Reply #2 on: November 24, 2010, 04:22:48 AM »
Thank you, Greg!
Last post April 14, 2010, 12:39:45 PM
Last post June 09, 2010, 06:37:54 PM
by jimmybass2
Last post November 10, 2010, 08:39:08 PM
by maachuu
Last post February 23, 2012, 07:24:10 PM
by LocDown
Last post October 26, 2014, 02:20:25 AM
Last post July 10, 2018, 05:05:34 PM
