Author Topic: GPS use  (Read 3888 times)
Wayne P.
  • Guest
GPS use
« on: October 21, 2010, 04:31:57 PM »
Your unit is set for North Up in the Navigation Menu. IF you have it set to Course Up, the map will rotate to the direction you are going.
Read your operating instructions.
Offline jerry b
  • Unit(s): 898c SI
  • Software: 4.97
  • Accessories: none
Re: GPS use
« Reply #1 on: October 21, 2010, 04:58:34 PM »
Wayne, same comments...where can I locate HOW to do this?
Wayne P.
  • Guest
Re: GPS use
« Reply #2 on: October 21, 2010, 05:51:24 PM »
Never mind, I read the manual and it states that the Chart Orientation setting does not apply in the Birdseye View, just the mapping view.
When you use that feature again and it does the same, push the "Exit" button. You can rotate the view with the 4-way key and if you do, you have to "Exit" to cease that function. You may have accidently hit the down arrow on the 4-way and made the view look backwards.
Read about the use of the Birds Eye view in your CD instructions.
I don't use that view and have it turned off in my "Views" tab.
