Author Topic: Side Scan Calculator - convert to SLG  (Read 17550 times)
Offline DannyGeysen
« on: October 20, 2010, 02:49:18 PM »
When viewing a SLG-file (converted from Humminbird DAT-file) in a Lowrance emulator, the position seems to be about 7 km south east of the real position.
The help-file of Side Scan Calculator is indicating that there might be a small inaccuracy (see below) but about 6 km seems to be very much ...  Who has experienced this too ?
Note: the latitude and longitude values shown in SonarViewer are somewhat inaccurate due to variations in the calculation formulas used by Humminbird and Lowrance for converting UTM meters to degrees. For better accuracy, use the “View”  “Options …”  “Mercator Meter” setting in SonarViewer.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: Side Scan Calculator - convert to SLG
« Reply #1 on: October 20, 2010, 06:45:04 PM »
Hello Danny and welcome to the forum.
I don't know the converter you're using, but I had problems with inaccurate positions when I used HumFinder and had choosen the wrong position format.
Make sure the format is right, maybe there's the problem.
Hope this helps!
Regards from germany / Harry
YES,......
WE SCAN!
Offline DannyGeysen
« Reply #2 on: October 21, 2010, 02:43:38 PM »
@  Jolly Roger
The converter used is from oceanecology/
http://www.oceanecology.ca/SideScanCalculator.htm
Offline keizerh
  • Unit(s): none
« Reply #3 on: October 22, 2010, 01:44:24 PM »
Why convert to SLG?
There are far more better converters/viewers for Humminbird files.
You'd better leave the lowrance viewer alone.
Hendrik
(Who is still waiting for a good Navico SLx to humviewer converter)
Offline DannyGeysen
« Reply #4 on: October 24, 2010, 10:59:12 AM »
Why convert to SLG?
Hendrik
Lowrance emulators are nice and free PC software for viewing both Sonar Logs and tracks on moving maps simultaneously. That's why I sometimes convert to SLG...
Offline burningla
« Reply #5 on: October 26, 2010, 03:30:38 AM »
Has anyone got a error message,"Cannot open file" with Side Scan Calculator?
I was running on Win XP.
La
Offline bobn
  • Unit(s): 997 csi
« Reply #6 on: October 26, 2010, 09:00:04 AM »
I am unable to open any of my files with the side scan calculator. The developer suggested  that the recording should have both 200 and 83 khz beams to work properly. I went out and took some recordings with both beams on, still doesn't open a file.  That along with the position error has me thinking this software isn't quite ready for prime time.
Offline Jim Jack
  • Unit(s): 998
« Reply #7 on: October 26, 2010, 01:11:19 PM »
Does Lowrance now have a SI emulator? I can not find it on there website if they do. Before their SI was released they had an emulator release date that kept slipping now I can not find any mention of it.
Thanks,
Jim
Offline DannyGeysen
« Reply #8 on: October 26, 2010, 04:26:06 PM »
Thanks,
Jim
Unfortunately, not yet. Only emulators for elder units and only 2-D sonar.
Besides this, Side Scan Converter is converting to SLG and not yet SL2 (which is sidescan and downscan)
Last post June 20, 2010, 04:38:42 PM
Last post July 26, 2011, 11:21:37 AM
Last post July 11, 2013, 09:40:37 AM
Last post August 06, 2013, 03:58:32 PM
by Rüdiger
Last post December 13, 2013, 05:38:31 AM
by peterv6i
Last post December 09, 2013, 02:58:50 PM
by peterv6i
Last post December 21, 2013, 11:03:29 PM
Last post August 03, 2019, 11:22:25 PM
by Gimp
