Author Topic: who use a mapping software ?  (Read 21611 times)
Offline abraquelebout
« on: October 01, 2010, 01:42:46 PM »
like dr depth or sonawiz
who know this software
Offline mendota
  • Unit(s): 1197
  • Software: 4.75
  • Accessories: AS-GRHA
Re: who use a mapping software ?
« Reply #1 on: October 01, 2010, 05:04:21 PM »
I use Surfer to create my maps.  It's not inexpensive software, but it is a bit more flexible than DrDepth.
I understand that DrDepth is very well supported by the software author, so I would recommend that path if you are non-technical.  It is also much less expensive than Surfer.
« Reply #2 on: October 02, 2010, 03:54:29 PM »
and for mosaïc ?
Offline plastikboot
    • Tauchdienste
  • Unit(s): 987, 1197
  • Software: Sonarwiz.Map 5, 4.95
  • Accessories: Cannon, Baro
« Reply #3 on: October 03, 2010, 07:02:42 AM »
Hi,
I use Sonarwiz.Map for mosaicing - it is quite expensive compared to Dr. Depth (which I use too for depth maps). The advantage is the professionality and that I can use it with the Humminbird-, Yellowfin- and Starfish-Data! The quality of the mosaics is very good.
Regards
plastikboot
Aquatically yours ;)______________________________
The truth is down there ;)
Offline Dale
    • Parks Victoria
  • Unit(s): (4 x) 997c
« Reply #4 on: December 17, 2010, 07:36:04 PM »
We use a combination of DrDepth for initial data processing, then importing into Manifold GIS for image processing and then further analysis. I'll put up a new thread describing this. We will be using Fledermaus  for sidescan processing within the next couple of weeks
Dale
« Reply #5 on: December 18, 2010, 04:00:28 PM »
We use 3DF.  It works well for our SAR and mapping.  There are programs to choose from and each will have its good points.  I posted on my page a sample of our 3df mapping.
Check out the replies here and hope you will make a good decision.
As alwasy, let us know the direction you go  and how it performs for you.
« Reply #6 on: December 19, 2010, 06:25:10 AM »
ok
service of regional archéology paid me dr depht
the first river card made with this software
it's easy to use, and intressting
now for more application, i make me a method to take datas and restitute more information
and i construct a new towfish, my first is working well but it take more place
i will post details on new post.
« Reply #7 on: December 19, 2010, 06:35:01 AM »
sorry i forget join my first card :-\ila_rendered
« Reply #8 on: December 19, 2010, 12:47:54 PM »
Remember that when using a towfish, that the depth recorded will be depth the  transducer on the towfish is off the bottom as measured from the towfish depth, not the surface to bottom depth.  Some setting will let you adjust the transducer offset.  Some mapping programs will let you offset the depth also.  Make sure to correct the depth readings when using the HB.
Chuck (Sonar2000)
Offline plastikboot
    • Tauchdienste
« Reply #9 on: December 19, 2010, 05:21:50 PM »
Hi,
for the towfish - depth problem: Humminbird has an easy solution - the Y-cable to use the sideimaging on the fish and the echosounder mounted on the boat. That way you get the best of both worlds ;) - and I the downrigger is still working perfect with this setup...
Aquatically yours
Plastikboot
« Reply #10 on: December 19, 2010, 05:25:59 PM »
Now that is a good idea.  You will get the correct depth you want AND also a clearer bottom display.  Good thinking.  It got by me on that.  I will have to remember the benefit of two transducers.
YOU ARE DA MAN.
Chuck(SONAR2000)
Offline Rickard
« Reply #11 on: December 19, 2010, 06:05:48 PM »
There is a problem with measuring depth from the boat while sidescanning from a towfish close the bottom. Ping rate in all channels, also the sidescan channels, will be controlled by depth info obtained from the transducer far above the bottom. This will cause a much lower ping rate than what's optimal. Low ping rate means you have to move even slower to avoid gaps in the sideimages.
Rickard
« Reply #12 on: December 20, 2010, 07:55:57 AM »
i think the problem is:
distance between towfish and gps recever,
in river the towfish is at 2 or 3 meter than the recever, yes for real depht you corect depht data
in one sequence on the file 000..there's more information
you find boo.son : 83 khz
b001.son : 200 khz
b002 . son, left  side data in 455 or 800 khz
boo3.son, right side data in 455 or 800 khz
you can extract the datas you want for application exept for 455 or 800 selected when you choose it.
and i agree whith all people, to make a correct depht map the hull mounting is prefered than other
Offline GM
  • Software: None
  • Accessories: None
« Reply #13 on: February 02, 2011, 08:53:25 AM »
I've used SonarWiz and Hypack, and let me say honestly, probably there are better software out there for mosaicing. I saw in one of these posts a mosaic made with DrDepth, I think it was posted by Mr. Robert Gecy. I was very impressed of the quality of the mosaic, of course, good mosaics are made usually with good quality data. Anyway, I'd be very grateful if someone can provide some examples of sidescan sonar mosaics.
Best regards
Offline GM
  • Software: None
  • Accessories: None
« Reply #14 on: February 02, 2011, 08:56:07 AM »
This is the post I refered to in my last message:
Code: [Select]
http://forums.sideimagingsoft.com/index.php?topic=1973.0
and yes, the mosaic was posted by Mr. Robert Gecy.
Last post June 28, 2016, 08:31:52 AM
by Mark Saikaley
Last post September 14, 2011, 04:04:10 AM
by bigkahuna
Last post February 16, 2012, 08:36:35 AM
Last post March 22, 2012, 11:14:35 PM
by stogazull
Last post May 30, 2012, 07:09:17 PM
Last post January 22, 2013, 04:21:30 AM
by Rüdiger
Last post March 28, 2013, 10:10:24 AM
by Triton Anlger
Last post June 03, 2016, 06:26:35 PM
by afaust
