Author Topic: Transducer adjustment lesson learned  (Read 6869 times)
Offline rwetzel@nc.rr.com
  • Unit(s): 997CNB, 797C2I SI Combo NVB
  • Software: 4.750, 4.770
  • Accessories: Weather Sense
« on: August 16, 2010, 10:32:37 AM »
I have a 17ft aluminum Starcraft, basically the same set up as a Tracker but has 2 livewells. I realized that when I have 2 or more people in the boat I have to lower the transducer figured this out this weekend when I lost the bottom once I hit about 17 MPH. I just updated the software so my initial thoughts were it was the software but once I lowered the transducer a little no issues and I got fish arches again not lines.
Offline soretoe
Re: Transducer adjustment lesson learned
« Reply #1 on: August 16, 2010, 02:05:22 PM »
When your transducer is lower in the water you will need to be more careful. Some have broken off after being struck by something in the water, even extra rough water will break the mounts also.
I have a tracker and my ducer is lower also. But I also run the HD transducer. I have not had a problem with it being lower and do get fairly good returns at 40MPH
I can also be found at;
Last post June 13, 2009, 03:44:25 AM
Last post May 19, 2009, 05:08:38 PM
by inshorecatch
Last post January 16, 2010, 04:22:56 PM
by soretoe
by Sonshine Fishing
Last post February 24, 2010, 07:39:14 PM
Last post April 23, 2010, 05:19:46 PM
Last post May 25, 2010, 02:41:14 PM
Last post June 23, 2010, 10:08:49 PM
by RV Sam
