Author Topic: si splitter cable  (Read 16908 times)
Offline wpda
si splitter cable
« on: July 29, 2010, 01:18:37 AM »
hi
if i am running 2 si transducers and a splitter cable for left and right how will this effect my 2d readings? which transducer will be getting used or will both?
IRC Kevin
  • Guest
Re: si splitter cable
« Reply #1 on: July 29, 2010, 05:19:05 AM »
I expect this will be the same as on my 997. Port transducer is Si only and starboard is Si, 2D and temperature. All functions seem to work fine with this setup, although there does seem to be a 'some transducers work better than others' effect. My port one is much clearer at depths over 160 feet and picks up targets at up to 220 feet, whereas the port one is very dark over 150 feet. (Can't complain as it isn't supposed to work at those depths anyway!)
Offline wpda
« Reply #2 on: July 29, 2010, 09:17:55 PM »
thats great thanks for that
where do you get your info from so i can try to find these things out myself
« Reply #3 on: July 29, 2010, 11:11:21 PM »
Someone else asked the question and we had the guru himself "Humminbird Greg" to answer it for us!
There is a wealth of knowledge here on the forum.  Browse around and use te search feature and don't be afraid to ask any question!
AS SI LR Y Cable Connections
Here are some great documents to look at in the Image Gallery / Documents /Wiring Diagrams
http://forums.sideimagingsoft.com/index.php?action=media;sa=album;in=39
Hope that helps.
Last post July 13, 2013, 06:51:56 AM
Last post August 07, 2012, 05:45:16 PM
by Paul D
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post January 17, 2017, 11:37:14 AM
Last post January 15, 2022, 04:20:46 AM
by TimTDP
Last post June 09, 2022, 08:53:44 PM
Last post September 05, 2022, 12:15:58 AM
by Swann
Last post November 17, 2023, 07:31:19 PM
