Author Topic: Help loading updated program  (Read 10690 times)
Offline tennwalkinghorse
  • Unit(s): 898cSI
  • Software: 6.420
« on: July 25, 2010, 04:07:26 PM »
I just finished installing my 898cSI unit. I noticed that when I loaded the Humminbird PC onto my computer and registered my unit and logged on to Humminbirds  web site that a updated soft ware version was available. I down loaded the 4.970 version on to a SD card as per the instructions. After the start up of the unit I noticed that the soft ware installed in the unit was 4.880 version. So I decided to install the newer version. I reset the defaults and powered the unit down ,installed the card on the left side slot,and powered the unit up. A window came up asking if I wanted to install the 4.970 version over the 4.880 one I said yes. Then a other window came up in red asking me if I was sure I wanted to replace the program I said yes. After the unit went into it's normal mode I powered it down,removed the SD card and started the unit back up. I checked the system screen to see if the up date took and it showed that the version 4.880 was still there NO update to 4.970. Could someone please tell me what I'm doing wrong.
« Last Edit: July 25, 2010, 04:10:03 PM by tennwalkinghorse »
Re: Help loading updated program
« Reply #1 on: July 25, 2010, 05:13:14 PM »
The 2nd question that the unit asked you was "Do you want to ABORT" this selection...you have to answer "No" to the 2nd question....
Read this for Robert's detailed directions for updating your unit...
http://forums.sideimagingsoft.com/index.php?topic=14.0
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #2 on: July 26, 2010, 04:02:57 AM »
Tennwalkinghorse you made two mistakes.1st answer yes   2nd answer no  after it updates before you do anything hit menu twice and restore
factory defaults again then you will be good to go.So just start all over and you will be fine hope this helps.   Gary
  • Unit(s): 898cSI
  • Software: 6.420
« Reply #3 on: July 26, 2010, 07:18:59 PM »
OK I'm a dumb ass that's what I get for not reading the question.  THANKS Guys for putting me on the right path. The upload went off with out a hitch 4.970 is in.
Thanks again
Mike
Offline stillbear
  • Stillbear
« Reply #4 on: July 27, 2010, 05:26:29 AM »
Mike  I am glad you got the update going. Thanks for letting us know. Gary
Last post October 15, 2017, 11:32:36 PM
by MikeM24108
Last post February 14, 2011, 01:43:04 PM
Last post August 07, 2011, 07:52:28 PM
by delmuts
Last post March 26, 2012, 08:36:33 PM
by Jim Gautney
Last post July 23, 2014, 03:42:56 PM
Last post August 22, 2014, 12:21:19 PM
by FlyFisher SLC
Last post September 22, 2014, 08:00:01 PM
by cary
Last post August 27, 2016, 06:18:26 PM
