Author Topic: Cant see brush piles on 997  (Read 11669 times)
Offline parker79
  • Unit(s): humminbird 997 side imaging
« on: July 21, 2010, 10:24:23 PM »
Wondering why i cant see some of my brush piles on SI and DI but can see them on sonar.
Offline calli1
  • Unit(s): 1198 S I & 787c2i
Re: Cant see brush piles on 997
« Reply #1 on: July 21, 2010, 10:38:13 PM »
Of course...I would first check all of the settings.
Then I would restore the unit back to the origional factory setting by default restore...."yes"
Try this....good luck.
« Reply #2 on: July 21, 2010, 11:09:38 PM »
Parker79,
Welcome to the forum.  Brush piles can be tricky sometimes.  Are these man made brush piles or natural?
The brush absorbs the water and the sonar passes right thru making it very hard to see sometimes.  The bottom hardness if strong can hide them also and you will need to look for the shadows of the brush vs the hard return of the brush itself.
What you can do is make a recording of a known brush pile keeping a very straight path.  Go slow, say less than 3mph and set the chart speed to around 3.  Play the recording back on the unit and pause the recording where you think the brush pile may be.  You can now adjust the sensitivity and other settings to see what works best to find them.  You can even change the colors.  Some colors show objects better than others.
See what works best for you and your area.  It will not always be the same, but you will start to learn what settings work best for different situations.
Good Luck,
« Last Edit: July 22, 2010, 08:39:24 AM by sonar2000 »
Offline parker79
« Reply #3 on: July 22, 2010, 11:59:31 PM »
Thanks Robert, they are man made and they still have leaves on them. Going to try recording and play with the sensitivity.
Craig
« Last Edit: July 23, 2010, 12:01:39 AM by parker79 »
Offline parker79
« Reply #4 on: July 23, 2010, 11:15:46 PM »
Calli1,
Set back to default seemed to work a little better.
Thanks,
Craig
« Reply #5 on: July 24, 2010, 01:48:01 AM »
Would love to see some snapshots if you have any.
Good Luck,
Offline parker79
« Reply #6 on: July 24, 2010, 11:36:18 PM »
Robert,
Tried to get some snap shots but my SDcard didnt work. Do I need a certain card or what. I've got a 2 GB SD card.
Online rnvinc
« Reply #7 on: July 25, 2010, 05:03:41 PM »
Make sure your snapshot is "enabled" in the menu system....
It's defaulted to "disabled" and pressing the "mark" button will only mark a waypoint without taking a snapshot....
Last post May 03, 2010, 02:05:35 AM
Last post May 03, 2010, 02:07:53 AM
Last post November 01, 2010, 09:31:31 PM
by Doug Johnston
Last post May 18, 2011, 06:51:27 AM
by stillbear
Last post April 17, 2012, 07:24:56 PM
Last post December 20, 2012, 09:15:56 AM
by LittleGazoo
Last post March 10, 2018, 09:05:39 PM
by pontooner10
