Author Topic: Difference  (Read 9675 times)
legend
  • Guest
Difference
« on: July 12, 2010, 03:45:33 AM »
Can anyone tell me what is the difference between TS2 W Transducer Switch and AS SIDB Y Side Imaging Splitter Cable.
Thanks.
Re: Difference
« Reply #1 on: July 12, 2010, 12:12:52 PM »
legend,
The TS2W Transducer switch will allow you to switch (manually) between two transducers.  Most common application, you could have an SI transducer on one side and a in-hull transducer (2d) on the other and be able to switch over to the in-hull at higher speeds for better 2d depth readings.  Or even have two SI transducers.  I have a switch where I can switch over to a second SI transducer mounted on a towfish without having to disconnect the cables.
From Humminbird Site:
Quote
Transducer Switch
This switch allows you to use two transducers on one depth sounder. The cable going to the depth finder is approximately 5 feet long and the two cables going to the transducers are approximately 20 inches long.
The SIDB Y Splitter cable is mainly used for the first example above.  It will split off the DualBeam "2d" portion from the SI transducer and hook into another transducer to take the dual beam from it.  Again, usually for better depth readings at higher speeds.  The 2d depth is taken from the second Dual Beam transducer only and the 83/200khz on the SI transducer is no longer used.
Quote
Y Cable - Side Imaging and Dual Beam - allows you to use two transducers on one unit without the use of a transducer switch. For use with Side Imaging products only, in conjunction with a dual beam transducer only. For improved high speed performance for bottom tracking.
legend
  • Guest
Re: Difference
« Reply #2 on: July 13, 2010, 01:20:55 AM »
Thanks RGecy!!!!!
Last post April 26, 2010, 09:53:42 AM
Last post January 02, 2011, 11:19:14 PM
by MonteSS
Last post January 06, 2011, 10:50:05 AM
Last post March 26, 2011, 11:05:19 PM
by jjbch
Last post January 26, 2014, 06:46:52 AM
Last post May 09, 2014, 05:15:52 PM
Last post April 16, 2018, 04:22:21 PM
by knorstu
Last post March 09, 2023, 11:20:45 PM
by ezfishn
