Author Topic: from Garmin GPS to my Humminbird 797  (Read 23677 times)
Offline zaccaria
« on: June 21, 2010, 01:47:03 AM »
Hello everyone, Does anyone know how I can move points from Garmin GPS to my Humminbird 797?
Re: from Garmin GPS to my Humminbird 797
« Reply #1 on: June 21, 2010, 07:56:21 AM »
zaccaria,
Here is a great online converter that will allow you to convert your waypoints to and from different formats.  You can use this to convert your Garmin waypoints to GPX format, and then import them Humminbird PC.  Then you can put them on your SD card and transfer to your Humminbird Unit.
http://www.gpsvisualizer.com/gpsbabel/
I think GPS Babel will also convert them directly to Humminbird Format and you can save directly to the SD card and transfer to the unit.
Either way should work fine.  Mess around with it and see what happens.  Just make sure you back up all your files first.
Good Luck,
Robert Gecy
Offline mendota
  • Unit(s): 1197
  • Software: 4.75
  • Accessories: AS-GRHA
« Reply #2 on: June 21, 2010, 09:57:38 AM »
EasyGPS is free and will connect to the Garmin directly via the USB port.  The files can be exported as .gpx files from there; Humminbird PC will combine .gpx track and waypoint files as required to upload them to the HB via SD card.
Offline zaccaria
« Reply #3 on: June 22, 2010, 12:30:40 AM »
Thanks to everyone I solved.
« Reply #4 on: June 22, 2010, 12:33:15 AM »
So what did you end up doing?
Offline jejb
« Reply #5 on: June 27, 2010, 08:29:15 AM »
The way I do it is pretty simple. Garmin's MapSource software, which comes free with all of their units AFAIK, has an option to save and import GPX file format. So just build what you want with MapSource and then save it as a GPX file. Then load that on your SD card and your unit automatically pulls it in.
John B
997C SI, 798CI SI  NVB
(formerly owned 1197C SI NVB)
Last post October 26, 2019, 07:53:17 AM
by Rüdiger
Last post July 21, 2016, 06:25:59 AM
by abraquelebout
Last post July 08, 2014, 11:25:31 AM
Last post March 21, 2015, 09:53:48 AM
by bigkahuna
Last post August 22, 2015, 09:48:18 AM
by DiveExplorer
Last post May 01, 2016, 12:37:10 AM
Last post January 17, 2017, 11:23:14 AM
Last post October 05, 2021, 08:44:56 AM
by oschi
