Software and Software Development
Software Downloads
(Moderator:
SIView
Topic:
Nothing happens
« previous
next »
Print
Pages: [
Go Down
Author
Topic: Nothing happens (Read 9564 times)
Lasse
Newbie
Unit(s):
979c
Nothing happens
on:
May 05, 2010, 03:31:49 PM »
I have a 797c unit with program version 3.460.
I have tried to upgrade to version 4.770, I downloaded the program, did exactly as the video described. But when I power up the 797 and put the SD card in the slot , nothings happens.
When I download the file I am told to open the file with VLC media .
Could this be the problem ?
Logged
Jolly Roger
Hero Member
HB Addicted
Unit(s):
HELIX 9 G3N, 998Cx SI, 959DI
Software:
latest (mostly)
Accessories:
AS GR50, custom towfish and: A boat!!
Re: Nothing happens
Reply #1 on:
May 06, 2010, 04:22:48 AM »
Hello Lasse and welcome to the forum!
You don't have to open the file with any program. Just download and SAVE the file on your computer.
If you have the SD card reader attached to your computer and the SD card in you can even save the file directly on the SD card by choosing the card as the place where to save it.
Hope this helps
Regards from Germany
Harry
Logged
YES,......
WE SCAN!
Lasse
Newbie
Unit(s):
979c
Re: Nothing happens
Reply #2 on:
May 06, 2010, 09:42:47 AM »
Hello Harry.
I have not tried to open the file whit VLC. Its just that when i download the file its automatically called "vlc media file bin file". I don't know if it makes any diffrents. But somethings wrong. Ive tried all sorts of ways to start the unit an insert my card but,nothing happens! Does the transducer and antenna need to be connected when you upgrade ?
Thanks for helping.
Logged
RGecy
Administrator
Unit(s):
1197c SI, 997c SI & 785c2
Software:
4.950 & 4.510
Accessories:
Interlink & GRHA
Re: Nothing happens
Reply #3 on:
May 06, 2010, 11:18:48 PM »
No, you do not need to have the transducer or gps connected. Make sure you have the right file. For example, the 798c cannot be updated with the 798ci file. If you downloaded the update from here, you need to make sure its correct for your unit.
If you registered your unit with humminbird, you can go to the Humminbird website and always find the latest update for your unit.
Good Luck,
Logged
Humminbird_Greg
Humminbird Helper
Humminbird Staff
I help because I can
Re: Nothing happens
Reply #4 on:
May 07, 2010, 03:09:58 PM »
Also make sure that the 797c unit is recognizing the SD card that you are using by making taking a successful screen snapshot.
Logged
Lasse
Newbie
Unit(s):
979c
Re: Nothing happens
Reply #5 on:
May 22, 2010, 08:44:05 AM »
I tried to update my friends 797 with my SD card and it worked!
When a got home i took a new SD card and the same program i have in my PC and this time i could update my own 797!
Strange things do happen.
Logged
works2much
Newbie
Unit(s):
797C2
Software:
3.4?
Re: Nothing happens
Reply #6 on:
May 28, 2010, 01:56:51 AM »
Im having a similar problem, I tried to update my unit and nothing happens (reset to factory defaults, put in card with download software from both this website and registered at HB), I tried 3 different SD cards (64MB, 1MB, etc), Any suggestions, Im about to throw the unit out of the garage haha
Logged
RGecy
Administrator
Unit(s):
Software:
4.950 & 4.510
Accessories:
Interlink & GRHA
Re: Nothing happens
Reply #7 on:
May 28, 2010, 09:13:42 AM »
works2much,
Welcome to the forum.
What is the file name of the software on the SD card?
Also, you have to make sure it is not in any folder on the card. When you open up the SD card drive, it should be in the root directory.
Logged
works2much
Newbie
Unit(s):
797C2
Software:
3.4?
Re: Nothing happens
Reply #8 on:
May 28, 2010, 09:33:12 AM »
M797c2.4_770.bin, Ive tried a Lexar and Scan Disk cards.
Logged
RGecy
Administrator
Unit(s):
Software:
4.950 & 4.510
Accessories:
Interlink & GRHA
Re: Nothing happens
Reply #9 on:
May 28, 2010, 12:01:55 PM »
As Greg suggested a few post above, make sure your unit is recognizing the SD card by taking a snapshot.
Logged
works2much
Newbie
Unit(s):
797C2
Software:
3.4?
Re: Nothing happens
Reply #10 on:
May 28, 2010, 12:55:59 PM »
I will try that once I get home. I noticed my software version is like 3.4 or something, and Ive read that some of the earlier versions don't take SD cards and I will need a MMC card, does this ring a bell?
Logged
RGecy
Administrator
Unit(s):
Software:
4.950 & 4.510
Accessories:
Interlink & GRHA
Re: Nothing happens
Reply #11 on:
May 28, 2010, 02:53:11 PM »
Well, it will take SD cards, but not SDHC cards. Try a small SD card like 512 or something. Once you get to 2gb, they are usually SDHC format. This may be your issue.
Logged
works2much
Newbie
Unit(s):
797C2
Software:
3.4?
Re: Nothing happens
Reply #12 on:
May 28, 2010, 04:54:19 PM »
Im unable to take a snapshot also, looks like Ill have to all humminbird! Thanks for your help!
Logged
RGecy
Administrator
Unit(s):
Software:
4.950 & 4.510
Accessories:
Interlink & GRHA
Re: Nothing happens
Reply #13 on:
May 28, 2010, 06:59:30 PM »
Did you try a smaller SD card less than 2gb?
Logged
works2much
Newbie
Unit(s):
797C2
Software:
3.4?
Re: Nothing happens
Reply #14 on:
May 28, 2010, 07:46:35 PM »
Yeah, I had a 64 MB card and it wouldn't pick that up either, I got it sent off today so we'll see what they say. Thanks again for the help!
Logged
Print
Pages: [
Go Up
« previous
next »
Smf
Software Downloads
(Moderator:
SIView
Topic:
Nothing happens
