Author Topic: Best Overall Settings  (Read 8486 times)
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« on: April 23, 2010, 08:45:50 AM »
I guess my question(s) are on the H B 898 or any sie image....what are the best settings for these units.
For example...sensitivity setting, how far out is the best range on the side scan, scan speed....etc.
What do you consider them best settings.  I plan to have mine back out on the water and running test.
Thank You....
Re: Best Overall Settings
« Reply #1 on: April 23, 2010, 08:52:44 AM »
Set the side scan distance about twice to three times the depth. then adjust as you see necessary.  If you are scanning changing depths you may have to keep changing the distance. A pain but it helps with the display.
Screen scroll speed is  usually matched to the speed of the boat.
SI is best at 2 to 4 MPH so your screen speed should be the same.
Sensitivity is your call for the best display.  You can adjust contrast and brightness also.
SI is a learning and a trial and error method for the good results.
Show us some picture as you practice.
Last post October 14, 2014, 07:41:13 PM
by slabbacks
Last post February 27, 2015, 08:51:56 AM
Last post May 29, 2015, 09:41:49 AM
by Thermite
Last post June 02, 2015, 05:43:53 PM
Last post June 08, 2015, 12:17:43 AM
Last post June 21, 2015, 12:42:49 PM
Last post July 26, 2017, 11:40:38 PM
by JOHN CASTELLUCCIO
