Author Topic: towed or not  (Read 11466 times)
Offline tournevase
  • ARCHAEOLOGICAL SURVEY
    • GRAS
  • Unit(s): HELIX 10 G4N CHIRP MEGA SI +
  • Software: AUTOCHART PRO
towed or not
« on: December 18, 2025, 04:51:12 AM »
hi everybody
i implement side imaging in rivers for archeological survey purposes.
the max depth is 4,5 m
the side range reach 2 x 50 m
today the transducer is attached to the boat under 25 cm of water
i wonder if it should be smart to use a towfish and at what depth
a problem should be when sailing near the bank line where it is too shallow
Tournevase
Offline Rickard
Re: towed or not
« Reply #1 on: January 06, 2026, 04:47:48 PM »
Hi, I have used a towfish and hull mounted transducers alot. It's possible to use a towfish close the surface, but it's so much simpler with hull mounted gear. I use hull mounted in waters much deeper than 4,5 m, down to about 20m with good results (in calm weather conditions).
Regards,
Offline tournevase
    • GRAS
Re: towed or not
« Reply #2 on: January 07, 2026, 04:53:13 AM »
thanks rickard
Tournevase
Last post December 08, 2010, 03:17:25 PM
Last post July 22, 2011, 02:42:19 PM
by Jolly Roger
