Author Topic: GPS issues + a side imaging issue  (Read 8537 times)
Offline finny
  • Unit(s): 798 si external GPS
  • Software: the last one
« on: September 26, 2023, 09:37:01 PM »
I have had my kayak in storage for a while.  Life, sigh.
I may not be able to get out again now that winter is coming but want to take a shot at resolving my FishFinder issues sorted before black friday.
I may not be able to get out again this year but I can always walk down to a large body of water and try the unit.
1.
My GPS puck was submerged for more than a week.  Not happy.
My Friends GPS puck worked on it.
Mine is no longer recognized, there was corrosion on the 4 pin connector that I cleaned off but the 4-pin may need to be replaced;  my next step may be to do that.  Does anyone have any tests I can perform?  I can read a schematic and know what a zener is and a bit more.
The GPS pucks are prohibitively expensive now, I remember when they were about $40.  Is there a cheap source for these?
#2
My kayak is peddle power and I am getting intermittent noise on the side not facing the peddles (mirage drive).
I also was unable to get the 2d bottom view to work (have reset and will retest this).
Is there a setting that swaps left for right transducer images?
thanks.
Re: GPS issues + a side imaging issue
« Reply #1 on: September 27, 2023, 09:50:33 PM »
This should be the pinout for the 4 pin connector  ... :
I don’t know of a board schematic available unless some creative tinkerer has created one for their own purpose  ...
If you just want to replace the cable connector you should be able to find an AS YC cable instead of replacing the entire GPS puck. AS YC has more wires than needed but you would only connect wires needed  ...
If you were not able to get any 2d views the unit is not recognizing that a transducer is connected  ...
If you are getting 2d views but showing no returns in the image the 2d piezo May be failing  ...
There is no setting is older core units to swap left and right SI  ...
« Last Edit: September 27, 2023, 09:53:12 PM by rnvinc »
Last post October 02, 2012, 11:00:38 AM
Last post November 17, 2013, 08:50:09 PM
Last post March 02, 2014, 05:30:28 PM
by FISHUNTR
Last post May 30, 2018, 08:11:04 AM
Last post April 15, 2020, 10:05:22 PM
