Author Topic: XT-6-24 Transducer Humminbird 405SX  (Read 19306 times)
Offline bigjohnbates
  • Unit(s): 405SX
  • Software: unknown
  • Accessories: xt6 20 transducer
« on: September 14, 2022, 12:50:20 PM »
Hey, I'm new to the forum with an upgrade question. I have an old (2007) Humminbird 405sx 200 kHz, single-beam fishfinder I use as a sounder on my bridge. It works but I want to replace it as the screen has seen better days, color would be nice. However I do not want to try and replace the XT-6-24 transducer as the boat is a 43 foot Sportfisher and I believe the transducer is a through-hull. Is there a newer Humminbird that uses the same transducer? The only one I see if the Wide 100 but that is the same era and not a color screen.
Thanks!
John
« Last Edit: September 14, 2022, 01:03:55 PM by bigjohnbates »
Re: XT-6-24 Transducer Humminbird 405SX
« Reply #1 on: September 14, 2022, 09:40:35 PM »
Internet Search for “Humminbird AD 926 adapter cable”  ...
HB no longer carries this but some online marine dealers may have one  ...
It will allow you to connect your transducer (number 6 - two pin) to a newer HB core 2d unit (number 9 connector)  ... (even the current line core unit HELIX products have an option to shut off CHIRP and transmit fixed frequency 200kHz - its simply a matter of matching the head unit transmit signal to the xducer piezo capability)   ...
Note: AD 926 indicates “ADapter” of 9 - 2 - 6  ... (number 9 to number 6)  ...
(The number designation is not pin count but HB cable end “connector shape” - in HB terms) ..
« Last Edit: September 14, 2022, 10:58:50 PM by rnvinc »
  • Unit(s): 405SX
  • Software: unknown
« Reply #2 on: September 15, 2022, 02:48:50 PM »
That is terrific info Rickie, thanks so much. I went to Humminbird online support and they just said the transducer didn't work with other units. Off to find the adaptor, cheers John
Last post May 01, 2011, 03:49:09 PM
by Roddy
Last post May 14, 2012, 04:40:30 PM
by lencho
Last post December 31, 2012, 02:10:10 PM
by geno368
Last post November 27, 2013, 02:23:18 AM
by Gimp
Last post April 10, 2015, 02:22:20 PM
Last post February 19, 2017, 06:08:06 PM
by 362 ranger pilot
Last post February 06, 2020, 09:36:12 PM
Last post May 03, 2021, 11:05:11 PM
