Author Topic: Hummingbird Basemap version 0000  (Read 9339 times)
Offline RogeKenW
  • Unit(s): Helix 7 chirp,mega,si gps Gen3
  • Software: 2.750
  • Accessories: none
« on: August 17, 2022, 02:43:54 PM »
Hi, I am new to this site and I am certain I am not the only one who has asked this question. I recently downloaded the new software version 2.75 to my Helix 7 chirp, mega, si, gps,gen3 and lost my basemaps. :-[  (My mistake). Talked to Humminbird tech and they told me how to reload it, but it didn't work.  >:( My question is will my unit function ok with my Lakemaps?
Thank you!
Re: Hummingbird Basemap version 0000
« Reply #1 on: August 17, 2022, 09:03:53 PM »
Yes  ... LakeMaster mapping is read directly from the mapping card so it should work regardless if the basemap works  ...
Offline RogeKenW
  • Software: 2.750
  • Accessories: none
« Reply #2 on: August 18, 2022, 08:00:21 AM »
Thank you Rickie!
« Reply #3 on: August 18, 2022, 09:58:25 PM »
How did Humminbird advise to reload the base maps  ... ??
Offline RogeKenW
  • Software: 2.750
  • Accessories: none
« Reply #4 on: August 19, 2022, 08:06:45 AM »
Hummingbird tech told me to format the SD card, Download the 2.010 onto the SD card only, Start up my Helix unit, restore to defaults, then power off, turn the unit back on, then put the SD card  in and wait for the prompts.  It prompt me to make a selection to load updated from 0.000 with Base map version 2.010  "Yes, No".  I selected yes. It prompt me to abort "Yes, No" I selected No. It then looped back to the first prompt.  I tried it several times, but it just keeps looping back to the beginning.
« Reply #5 on: August 19, 2022, 10:08:16 PM »
You might try downloading the update from Humminbird again  ...
Maybe the download got corrupted somehow from Humminbird  ...
Offline RogeKenW
  • Software: 2.750
  • Accessories: none
« Reply #6 on: August 23, 2022, 11:15:33 AM »
Yes, I tried it several times without any luck. Formatting the SD card, downloading version 2.010 from Humminbird's support website and get the same results.  I can't understand why it cost so much for Humminbird to install the software ~$230.00
Offline ezfishn
« Reply #7 on: August 23, 2022, 07:16:43 PM »
Unless the unit is covered under warranty, they have a flat rate repair program.  They charge the same rate for any repair unless it is screen related.  I believe that's the cost for your unit.
https://humminbird-help.johnsonoutdoors.com/hc/en-us/articles/4412767762839-Current-Repair-Fees
Last post June 10, 2009, 02:44:47 AM
by petervanbergman
Last post November 11, 2009, 01:13:25 PM
Last post November 11, 2010, 02:01:42 AM
by tghinson
Last post April 16, 2011, 06:58:49 PM
by snookhooked
Last post November 16, 2011, 02:00:18 PM
by fresque93
Last post December 30, 2012, 11:15:48 AM
Last post February 14, 2016, 10:37:16 PM
Last post May 09, 2017, 10:14:22 PM
