Author Topic: Not happy  (Read 10786 times)
Offline pig75
  • Unit(s): 798, matrix17, lcr400
Not happy
« on: April 14, 2010, 04:56:15 AM »
Ok my first 798 kept rebooting so i send it back 2 weeks later they send me a new one now this one has no internal GPS  >:( it sayes internal GPS on the cover. In the accesory test it sayes GPS unconected.
I asume this unit is falty too ?
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
Re: Not happy
« Reply #1 on: April 14, 2010, 06:54:16 AM »
Hi pig sorry to hear you are having troubles with your new unit. Have you hooked your antenna up? Are you outside where the head can see the sky? The first initial time the unit takes a little
time to get a fix .Robert here on the Forum Owner and Gregg Walters HB Rep .Will probably
add something.    Gary
Re: Not happy
« Reply #2 on: April 14, 2010, 02:09:30 PM »
Make sue that your unit is outside so it can track the satellites.  If it is you may need to contact the Humminbird Customer Resource folks at 1-800-633-1468 to get another unit sent out to you.
Offline pig75
Re: Not happy
« Reply #3 on: April 14, 2010, 04:51:13 PM »
add something.    Gary
No antenna it's a internal unit
As i am outside the US i do not think Humminbird Customer Resource will be much help
Re: Not happy
« Reply #4 on: April 16, 2010, 01:53:02 PM »
Sorry Pig75, I did not look where you were located.  Who are you working through: BLA?
When you power the unit on does it say on the title screen that it is a “798c Si Combo” or “798ci Si Combo” (not additional “ i “ in model name.  Also, look at the serial number and see which model it says.
Offline pig75
Re: Not happy
« Reply #5 on: April 16, 2010, 08:31:26 PM »
Yes it's going through BLA . Received another unit today looks like this one works  :). Must give them credit they sent the new unit straight out. No waiting for the other unit to be sent back. Now i can try this thing on the water
Offline pig75
Re: Not happy
« Reply #6 on: April 17, 2010, 04:41:18 AM »
OK took the unit out and it was great  :) but no down image. It had firmware version 4.73 so dumb me did a update to 4.78 >:( now this unit is rebooting  >:( >:( Is anybody having trouble with the international 798ci ??
Also the 4.73 firmware is in the 798c section and not the 798ci section.
So what do i do now ?
Offline stillbear
  • Stillbear
Re: Not happy
« Reply #7 on: April 17, 2010, 09:20:54 AM »
PIG 75 Looks like what ever you are doing you are consistant.I think you need to call Tech
support all these units cannot be broke sounds like a setup problem.  Gary
Re: Not happy
« Reply #8 on: April 17, 2010, 03:46:15 PM »
How did you do the update?  SD card or pc connect cable?
Did you put the SD card in before or after you powered on the unit and did you restore the defaults?
Did the unit give you a green screen at the end saying the update was successful?
If you stick an SD card in the slow with an update on it will it recognise it?
Let me know and we will get you on track.
Offline pig75
Re: Not happy
« Reply #9 on: April 17, 2010, 05:11:47 PM »
I did a reset to default then used a PC connect cable. The version of HumminbirdPC is 3.0.26
Re: Not happy
« Reply #10 on: April 17, 2010, 08:53:21 PM »
Since you have the PC connection cable I would try to either restore it in boostrap mode or stick the previous update on an SD card and see if it will start the update.  Backdate it to the previous then use the SD card to put the new update on there.  Power on the unit, restore defaults, then insert the sd card (do not power off!)  Let it do the update, then when it reboots, restore the defaukts again.
Good Luck,
Offline pig75
Re: Not happy
« Reply #11 on: April 18, 2010, 12:33:01 AM »
It looks like it is only rebooting in demo mode (i can live with that) took it out on the water for about 2hrs it never missed a beat
Last post October 16, 2011, 01:18:57 PM
by Roddy
Last post November 18, 2011, 12:25:53 AM
Not too happy
Started by dp 898c SI
Last post September 28, 2013, 09:31:30 AM
by dp
Last post March 24, 2014, 06:56:44 PM
Last post November 28, 2014, 12:21:51 AM
Last post December 31, 2014, 09:56:13 PM
Last post March 02, 2015, 04:26:56 PM
by cats-n-craps
Last post March 06, 2015, 05:06:14 PM
by Gimp
