Author Topic: Body Recovery  (Read 10857 times)
Offline xd35
  • Unit(s): 798si/1197si
Body Recovery
« on: April 13, 2010, 10:08:59 AM »
Found this well written piece while doing some research and thought I would share it with the S&R Folks.
Interesting Note:
"Because the human body has such a high percentage of water in it, it is not a strong acoustic reflector. Air filled organs or SCUBA cylinders, if present, can be seen as bright reflections with low to mid range freq sonars.
http://pro-rov.com/images/Human_Body_Search_Recover_Using_Mini-ROVs_19Jan09__Formatt.pdf
Re: Body Recovery
« Reply #1 on: April 13, 2010, 11:23:20 AM »
HMMMM interesting.    Bodies will indeed reflect a lot of return,  depending on the length of decomposition.  During the later stages it will be less.  Look at sonar images of bodies posted by sonar builders.
 Cylinders will reflect signal but have a tendency to let the signal slide around and not reflect.  Kind of like a stealth plane and radar. Round objects are like this.
Objects filled with air will let the signal pass thru the air and relies on the back of the object to reflect. Again look at this the same way as sonar and air filled water behind the propellor or the wake of a boat.  Or in the area below a dam where water is being released.
I will have to look at this article.
First view of the article looks like a marketing write up.  Farther in the article is talks about sonar and then shows a couple of bodies.  having seen sonar and bodies first hand I have a bit of trouble with the statement.   I think you will be fine with bodies search and sonar . However there are issues with getting a good signal to depict the bodies depending the other stuff around the body ....a flat bottom by itsself you will have not problem.
« Last Edit: April 13, 2010, 11:38:15 AM by sonar2000 »
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: Body Recovery
« Reply #2 on: April 13, 2010, 11:26:00 AM »
Thanks for the link XD!
Very interesting and good written article.
Regards / Harry
YES,......
WE SCAN!
Last post June 27, 2010, 10:47:36 PM
by calli1
Last post September 22, 2011, 08:17:47 PM
by Roddy
Last post April 09, 2012, 02:50:39 PM
Last post March 07, 2013, 06:57:05 AM
by Walter
Last post August 06, 2015, 11:30:42 AM
by Spd 135
Last post April 13, 2015, 08:35:29 AM
Last post March 14, 2016, 04:45:17 PM
Last post May 03, 2019, 04:26:46 AM
by Rüdiger
