Author Topic: creating waypoints Helix 9  (Read 8645 times)
Offline redriverguy
  • Unit(s): Helix 5, Helix 9
« on: July 05, 2021, 04:38:54 PM »
Here is my issue.  I create a waypoint using the menu system inputting the coordinates of the location and save it.  Then when I try to GO TO the created waypoint it routed me to a location that is different from the input coordinates even though the input coordinates are showing as correct.  Also, if I use the Mark button to create a new waypoint and then use the Go To button to get back to that location it works perfectly.  Does any one have any ideas?  Thank you
Re: creating waypoints Helix 9
« Reply #1 on: July 05, 2021, 08:57:56 PM »
Default format for HB waypoints is Degrees Decimal Minutes  ...
If your waypoint format is in a different format from that - you will need to change the HB unit format under the Setup tab and down to “Position Format”  ...
« Last Edit: July 05, 2021, 09:04:41 PM by rnvinc »
Offline redriverguy
« Reply #2 on: July 06, 2021, 09:36:54 AM »
I think that the waypoint format is correctly set but I will verify that when I get down to the boathouse.  Thanks for the reply
« Reply #3 on: July 06, 2021, 09:01:22 PM »
Degree Decimal minutes would look like xx°xx.xxx’
Last post March 20, 2010, 05:37:59 PM
by twobearlake
Last post May 10, 2011, 09:31:30 PM
by neeper67
Last post March 20, 2012, 01:03:36 PM
Last post May 22, 2012, 07:59:57 AM
Last post October 10, 2015, 11:36:22 AM
by LittleGazoo
Last post October 09, 2015, 03:03:10 PM
Last post April 09, 2016, 11:52:00 PM
by wingrider99
Last post April 10, 2024, 11:10:43 AM
by Kenai
