Author Topic: Can't link up units to ethernet Hub  (Read 6643 times)
Offline CSThao
  • Unit(s): Helix 9 SI
« on: May 09, 2021, 09:11:29 PM »
Hello Guys,
So I recently bought an Ethernet unit along with all the cables required. Once I finished the installation, for some reason I can't seem to get one of my helix 9 units to show the network tab. I've tried resetting to default, unplugging the cables and plugging it back on, etc. Both my units are the KVD helix 9 models. Am I doing something wrong?
Re: Can't link up units to ethernet Hub
« Reply #1 on: May 09, 2021, 11:01:25 PM »
There are reports of specific ports may not work  ...
Try moving the connection to a different port on the AS ETH 5XPG  ...
Offline CSThao
« Reply #2 on: May 10, 2021, 05:43:08 PM »
Yeah, I've tried all ports and still have the same issue. It's probably not the port from the hub that's an issue here I think.  Because no matter what port the cables are in, I test them on both units. One is showing the network tab while the other isn't. I have a feeling its the Helix unit that's faulty, however its out of the warranty considering its a first gen unit. Does anyone else have other ideas what the problem could be?
Offline CSThao
« Reply #3 on: May 10, 2021, 06:48:32 PM »
Just a little update, I just realized that if I'm just using 2 units I wouldn't need to use the ethernet hub. However, after doing a direct link from unit to unit, it still came out with the same outcome. One unit has the network tab and the other doesn't.
« Reply #4 on: May 10, 2021, 10:18:54 PM »
Have you tried Restore Defaults  ...??
Have you updated the software  ... ??
Offline CSThao
« Reply #5 on: May 10, 2021, 11:19:06 PM »
Yeah, I tried pretty much everything.  Suggestions I read up on other forums, etc. The last version for 1st gen was back in February 2019. Resetting to default did nothing. I'm at a lost of what else I can do.
« Reply #6 on: May 11, 2021, 09:46:38 PM »
You mentioned the AS ETH 5XPG in the OP - this means you should have at least 2 Ethernet cables  ...
Try the other one direct connected between the units  ...
Last post March 20, 2012, 02:17:18 PM
by Gattlin
Last post July 14, 2011, 01:57:14 AM
by Roddy
Last post September 20, 2011, 09:42:37 PM
by knorstu
Last post February 06, 2013, 01:27:24 PM
by didier74
Last post March 13, 2013, 08:51:49 PM
by freezerfiller
Last post February 26, 2014, 02:19:18 PM
by castle rock clown
Last post July 30, 2015, 11:22:29 AM
by tjstalb
Last post January 21, 2018, 11:31:39 AM
by suvowner
