Author Topic: Using 898c si for ice fishing  (Read 14169 times)
Offline mossboss
  • Unit(s): 898c si
« on: January 18, 2021, 07:49:16 PM »
Anyone ever use there 898 si for ice fishing, was wondering if it is possible. I know the side image would not work with no movement, but I figured the down image should. Any help would be great
Re: Using 898c si for ice fishing
« Reply #1 on: January 18, 2021, 09:08:42 PM »
DI in the 898 is a computer generated rendering from the data received by the SI piezoes (no DI piezo)  ...
Therefore DI also needs movement to create the DI image  ...
2d should work fine not moving  ...
Offline D S
  • Software: 7.5
« Reply #2 on: January 20, 2021, 09:57:45 AM »
rikki
are there not transducers with a dedicated DI piezo?...if so do they have to be moving as well to work?
stgr
« Reply #3 on: January 20, 2021, 09:30:07 PM »
ONIX, SOLIX, APEX, HELIX G2N, G3N, G4N in 8” and larger have a dedicated DI piezoe  ...
DI is wide (side to side) and narrow (front to back) and needs movement to create a discern-able image  ...
A stationary DI will show targets as horizontal lines across the screen (because the beam is repeatedly hitting the same target over and over)  ...
« Last Edit: January 20, 2021, 09:31:22 PM by rnvinc »
Last post May 28, 2009, 08:45:10 PM
Last post October 28, 2011, 10:40:38 AM
by raricker
Last post January 01, 2012, 06:43:13 PM
by reddog
Last post December 11, 2013, 05:20:47 PM
by jepik
Last post July 21, 2014, 01:19:03 AM
by Trav
Last post November 21, 2014, 11:56:49 AM
by Rickard
Last post December 15, 2015, 04:52:06 PM
by CamoHunter
Last post January 12, 2017, 05:34:21 PM
by Gimp
