Author Topic: AIS Reciever with 1198  (Read 12034 times)
Offline houtxfdcapt
  • Unit(s): 1198c SI Combo
« on: July 06, 2020, 01:31:07 PM »
Hi guys, new to the forum, glad to be here.  I have a lot to learn.
I ordered an AIS.   It will be receive only.  I have no NMEA2000 hooked up on the boat.    My question is if I go straight from the AIS N2K out to the 1198 N2K in will it work? 1198 has the round N2K right.. the search on the site referred to the 1197 with only the RS232? or do I have to install the bridge with power.
Thanks so much!
« Last Edit: July 06, 2020, 01:39:29 PM by houtxfdcapt »
2001 Scout 240 CC
Re: AIS Reciever with 1198
« Reply #1 on: July 06, 2020, 09:57:27 PM »
If no one pops in with info - Humminbird may be able to help  ...
1-800-633-1468
Offline houtxfdcapt
« Reply #2 on: July 06, 2020, 10:12:05 PM »
Thank you sir
2001 Scout 240 CC
Offline ezfishn
« Reply #3 on: July 09, 2020, 01:36:08 PM »
Not familiar with using the AIS receiver with HBs but found the attached link related to using a receiver with RS-232 output.  If you are able to use one with NMEA2000, it would require the Humminbird AS ETH NMEA2K adapter and backbone.  The 1198 is NMEA0183.  Good luck and would definitely try to get confirmation/info from Humminbird.  I know HB used to have a AIS receiver but was discontinued some time ago and would assume current unit software may restrict which AIS receiver models may be even compatible.
https://www.humminbird.com/sites/humminbird_site/files/ais_connection_ig_532458-2_a.pdf
Last post April 25, 2016, 11:30:47 PM
Last post October 24, 2009, 09:42:29 PM
Last post November 04, 2010, 07:22:45 AM
by Wayne P.
Last post January 06, 2011, 08:35:26 AM
by stillbear
Last post December 06, 2011, 05:17:17 PM
by Rick James
Last post April 15, 2013, 12:51:21 PM
Last post July 13, 2014, 09:53:52 AM
by hoffa09
Last post April 16, 2015, 10:11:02 AM
