Author Topic: Helix 8 si transducer question  (Read 5606 times)
Offline Beerz
  • Unit(s): Helix 8 mega si+ g3n
  • Software: v2.180
« on: May 31, 2020, 09:16:57 PM »
so I recently bought a helix 8 si this is my first si unit. Having the transducer mounted like this will it work fine or will I get interference? Thanks
Re: Helix 8 si transducer question
« Reply #1 on: June 01, 2020, 09:41:46 PM »
The SI beams reach all the way to the water’s surface on each side  ... you may have some blockage  ...
The easiest way to discern this is to test where you have it and then compare with the xducer farther down in the water (either some kind of extension of your bracket downward or on a separate stick)  ...
« Last Edit: June 01, 2020, 09:42:55 PM by rnvinc »
Last post July 16, 2015, 10:48:12 AM
by Beaulieu80
Last post January 06, 2016, 09:46:14 PM
Last post February 15, 2016, 10:01:01 PM
Last post March 07, 2016, 11:14:58 AM
Last post November 09, 2017, 08:32:56 PM
Last post June 26, 2019, 08:02:48 AM
Last post February 27, 2020, 09:50:10 AM
by JDM70
Last post April 13, 2020, 10:32:30 PM
