Author Topic: Units supporting LIVE DATA on the water  (Read 14094 times)
Offline Renoboss
  • Unit(s): 2x Helix 9 G3N / CF-19mk3
  • Software: V2.28, Autochart Pro
  • Accessories: Ethernet Switch
« on: May 06, 2020, 02:22:53 PM »
Hi Guys,
Does anyone know which units of the Helix and Solix series support Live DATA on the water to a laptop ?
main use Ethernet connected !!
i'm hearing mixed info about not being possible to Solix and Helix G2 en G3.
Currently still running HB1197cxi on DrDepth BT+SS.
Thanxs
(Used HB997cxi ,  HB1197cxi , DrDepth BT+SS.)
Offline Rüdiger
Re: Units supporting LIVE DATA on the water
« Reply #1 on: May 11, 2020, 03:40:30 AM »
I would also be interested, because I also use DrDepth. The live Sidescan mosaic function is the most important for me.
mvh
Rudiger
Finding is better than losing
Offline sss_floripa
  • Unit(s): HELIX 10 CHIRP MEGA SI+ GPS G3N
  • Software: 2.110
  • Accessories: AutoChart Pro 2.300
« Reply #2 on: May 23, 2020, 05:16:04 PM »
I have Helix 10 MSI G3N (v 2.110) connected via Ethernet with the laptop and I use AutoChart Pro v2.300 (Released on 15/06/2018).
Unfortunately, AutoChart Pro cannot obtain live images using the MEGA frequency.
Functional only with 455Khz and 800Khz.
In October 2019, I opened a link on the Humminbird website and was informed that, unfortunately, they had no plans to make AutoChart Pro compatible with live images on the MEGA frequency.
So far, Humminbird has not made any updates to the AutoChart Pro software which is out of date in my opinion. :-[ :-[
Offline Renoboss
« Reply #3 on: June 06, 2020, 05:41:24 AM »
Installed AC-pro v2.3 on my laptop.
HB1197 running v6.31 unable to complete to a working connection due to not being able to select correct 200khz transducer.
So installed v6.64 on the HB1197.
Now the correct settings were selectable and able to complete the live connection to AC-pro v2.3.
Regards,
Offline Renoboss
« Reply #4 on: September 13, 2020, 10:01:16 AM »
Hi guys,
Sold my HB1197.
Now running 2x Helix 9 G3N msi with Ethernet switch.
Today on the water the connection to my laptop running Autochart Pro V2.3 i'm losing the depth measurement.
Disconnect and reconnect with F3 immediately brings back depth.
But after appr. 3 minutes is loses depth again....
Headunit running V2.28 with basemap V1.030.
regards,
Renoboss
Last post April 23, 2009, 09:43:47 AM
Last post August 07, 2011, 06:52:09 PM
Last post April 24, 2016, 10:56:12 AM
by Rpadar
Last post July 31, 2019, 09:03:54 PM
Last post August 02, 2019, 02:35:25 PM
by knorstu
Last post April 01, 2020, 08:58:39 AM
Last post April 02, 2020, 12:40:09 PM
by knorstu
Last post July 10, 2021, 08:45:22 PM
