Author Topic: Does HumViewer really work?  (Read 9888 times)
Offline Kkcollins
  • Unit(s): SI Helix 10 gen 2
« on: March 21, 2020, 08:02:58 PM »
Hey group I'm Kevin. New to the forum.
I downloaded HumViewer to view my Humminbird Helix 10 SI Gen2 videos.  But I copied them to my desktop from my SD card and tried to open the .DAT files from the folder and I keep receiving this Error message.
Re: Does HumViewer really work?
« Reply #1 on: March 22, 2020, 08:45:51 AM »
Does the recording successfully playback in the HELIX  ... ??
Offline Kkcollins
« Reply #2 on: March 22, 2020, 12:09:24 PM »
Yes all of them do.  Very well I might add.
« Reply #3 on: March 22, 2020, 09:33:10 PM »
When you click on File/Open and point Humviewer to the folder with your recording data and then select a DAT file and select open  ... does Humviewer look like it’s loading the B001, B002, B003 files?
 (from your ScreenShot it looks it loaded all the way to the B004 file)
« Last Edit: March 22, 2020, 09:35:51 PM by rnvinc »
Offline Kkcollins
« Reply #4 on: March 23, 2020, 08:01:38 AM »
Exactly correct. Chugs along like it's working and then it hangs on #4. Then nothing.
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Software: Latest Versions
« Reply #5 on: March 23, 2020, 08:29:48 AM »
Rename the B004 folder to X004.  Then reload Humviewer. Your file will open.
Offline Kkcollins
« Reply #6 on: March 23, 2020, 08:50:02 AM »
I don't have a B004 folder.  Could that be the problem? My FF doesn't have a B004 folder either. I've attached my file structure of what I DO have.
Offline jimham82
  • Jim Hammond
« Reply #7 on: March 23, 2020, 09:53:48 AM »
I haven't done this in a while.  The problem is caused by the B004.IDX and B004.SON files used for Mega down imaging.   If you create a folder and move these two files to it, Humviewer will then open the recording successfully.
Here's a video on the topic:  https://youtu.be/qvelxOOcY54?t=19
Offline Kkcollins
« Reply #8 on: March 23, 2020, 11:51:56 AM »
That fixed it.  Thanks Jimham. This is pretty cool!!!
« Reply #9 on: March 23, 2020, 09:16:45 PM »
Thanks Jim for jumping in here  ...
I don’t have HELIX to even have experimented with this  ...
Offline Kkcollins
« Reply #10 on: March 27, 2020, 01:24:27 PM »
Is there a way to change the color from green to the color the Humminbird has?
Offline reso
  • Unit(s): Matrix 37, 997 CSI,Helix 12 Chirp
  • Software: latest
  • Accessories: interlink, high accuracy gps,360 TM
« Reply #11 on: March 27, 2020, 08:04:07 PM »
Yes, there is a topic on this subject in the forum and it works great.
Search on this forum for True 'Brown'  and you will find it.
Cheers,
Reso
Offline Kkcollins
« Reply #12 on: March 28, 2020, 03:53:20 PM »
Thanks for the tip Reso but I downloaded it and copied where I was told and now when I open HumViewer it will not open the color model editor to change the color over to the brown color.
Offline Kkcollins
« Reply #13 on: March 28, 2020, 04:47:39 PM »
I click on it and nothing happens.
Offline reso
  • Software: latest
« Reply #14 on: March 28, 2020, 09:06:11 PM »
I just followed fishshtick 's instructions and have it both working on my pc and laptop, looks almost as the original color on my HB when playing back.
Make sure you rename the .txt file correctly and place it in the right location, it should work.
Offline reso
  • Software: latest
« Reply #15 on: March 28, 2020, 09:12:02 PM »
if you added it permanently, like i did, you open the recording, right mouse click on the recording view when you play it and select Color Schemes and click on HB Brown
Dont use color editor
Offline Kkcollins
« Reply #16 on: March 28, 2020, 09:43:55 PM »
My only option is grey scale.  Does that mean I haven't renamed the file correctly?
Offline Kkcollins
« Reply #17 on: March 28, 2020, 10:19:13 PM »
Got it. Now it's working?
Last post January 11, 2010, 09:43:16 PM
Last post July 02, 2012, 09:40:28 PM
by HenryNguyen
Last post December 11, 2012, 09:33:46 AM
by TroyBoy30
Last post March 12, 2015, 09:57:20 AM
Last post April 06, 2015, 11:26:33 AM
Last post December 16, 2015, 08:09:40 PM
by jabsy
Last post March 29, 2019, 09:31:40 AM
by grizwilson
Last post February 25, 2020, 12:54:25 PM
by ezfishn
