Author Topic: Multiple Transducer Source for MSI  (Read 15859 times)
Offline Lakefront
  • Unit(s): 997 SI, 597 SI
« on: October 05, 2019, 10:55:41 AM »
I am looking to upgrade to the MK Ulterra trolling motor w/Chirp, built-in MSI/MDI, & iPilot Link. I have a Helix 10 MDI G3 on bow and Helix 12 Chirp MSI/MDI G2N at console. If I network these will I be able select the TM TD on my Helix 12 to show MSI at the console head unit?
Re: Multiple Transducer Source for MSI
« Reply #1 on: October 06, 2019, 09:28:46 AM »
« Last Edit: October 06, 2019, 09:30:22 AM by rnvinc »
Offline Lakefront
« Reply #2 on: October 06, 2019, 03:11:12 PM »
Thank you for the link. Before I buy the new Ulterra, I wanted to be certain that I can display the MSI at the console from the trolling motor. Is there a way to switch between the built-in trolling motor MSI TD and the transom MSI TD?
« Reply #3 on: October 08, 2019, 10:29:44 PM »
Both connected xducers should be available under the Network Source tab in the Main Menu System  ...
Offline Lakefront
« Reply #4 on: October 12, 2019, 08:23:52 PM »
Ricki- Thank you for confirming.
Offline ezfishn
« Reply #5 on: October 13, 2019, 05:28:46 PM »
Just curious why wanting to view MSI from TM at console which would require TM to be deployed?
Offline Lakefront
« Reply #6 on: October 14, 2019, 08:20:52 AM »
If I want to see out to the side of boat while trolling. Right now, I only have Helix 10 MDI at the bow- the built-in MSI was not available when I bought the 10.
Offline Lakefront
« Reply #7 on: December 07, 2019, 09:42:14 AM »
RNVINC- I contacted HB support and they said that if I connect the built-in MSI TD from my new Ulterra to my console Helix 12 MSI head unit, and link my bow Helix 10 MDI, it would display MSI on my bow head unit. Also, in the Network setup, I could also select my transom TD to show MSI from my console head unit, Helix 12 MSI. Does this sound correct? Just wanting to make sure before i invest $3200 for my new Ulterra- Thanks
« Reply #8 on: December 07, 2019, 01:44:01 PM »
It is also my understanding that the MSI xducer needs to be connected to the MSI head unit  ...
This is so the MSI head unit can process the SI data from the Ulterra MSI xducer ... which can then be shared over Ethernet to the other head unit display ...
« Last Edit: December 07, 2019, 01:47:33 PM by rnvinc »
Offline Lakefront
« Reply #9 on: December 07, 2019, 04:14:13 PM »
Rickie- Thank you for confirming.
Dave
Last post March 28, 2010, 09:56:15 PM
by Perrard
Last post October 27, 2011, 07:46:29 AM
by bigkahuna
Last post July 24, 2012, 11:31:27 AM
by Roddy
Last post April 12, 2012, 06:50:35 PM
by Papa
Last post April 23, 2013, 06:44:09 PM
by Alloutdoors
Last post May 08, 2018, 11:03:19 PM
Last post August 06, 2019, 08:31:22 PM
Last post September 19, 2020, 08:14:06 AM
