Author Topic: ARCHES  (Read 9951 times)
Offline ATB1134
  • Unit(s): 1197SI 797SI
ARCHES
« on: April 06, 2010, 05:27:11 PM »
I CAN'T SEEM TO GET FISH ARCHES WORKING ONLY THE ICONS? ANY HELP
Re: ARCHES
« Reply #1 on: April 06, 2010, 05:47:38 PM »
If you want the Fish ID on, you are fine, else turn it off in the Sonar Menu.
As for the fish arches, you may need to tilt your transducer down a little (or up).  Can you post a snapshot of what you are seeing on the screen.  Preferrably with Fish ID off, and this will help us see whats going on.
Good Luck and let me know if that helps,
Offline ATB1134
Re: ARCHES
« Reply #2 on: April 06, 2010, 05:55:58 PM »
WILL POST PIC AFTER THIS WEEKEND
Offline xd35
  • Unit(s): 798si/1197si
Re: ARCHES
« Reply #3 on: April 07, 2010, 10:35:31 AM »
Pretty sure it will not show arches with fish id in the ON mode. When you turn it off, it will reflect arches vs those little little arcade fish. ;D
Select menu tab and then Sonar Fish ID OFF.
« Last Edit: April 07, 2010, 10:36:33 AM by xd35 »
Re: ARCHES
« Reply #4 on: April 09, 2010, 01:09:57 PM »
Actually when the user selects to show the Fish ID Symbols we show them over the processed sonar (what you would normally see), we do not cover up the sonar reading with the Fish ID Symbol.  Turning the Fish ID Symbols off just eliminates the fishy above the arch (if your unit was going to show the fish with an arch).
Last post July 06, 2009, 10:35:19 AM
Last post May 05, 2010, 04:17:08 PM
by Wayne P.
Last post July 25, 2010, 09:46:24 PM
Last post August 19, 2011, 01:56:00 AM
Last post March 12, 2014, 03:27:59 PM
by Tjo
Last post May 24, 2016, 11:22:41 PM
by RonnieB
