Author Topic: 10" mega helix si issues  (Read 8389 times)
Offline Fresnoron
  • Unit(s): 898 Si, Helix 10 mega si
  • Software: Navionics Platnum
« on: May 09, 2019, 07:37:27 PM »
have a new 10" mega helix si unit...been working great until today...on SI, left side perfect, right side so dark almost cant see it...also DI is same way...so dark you cant see anything. everything else works great    thx Ron
Re: 10" mega helix si issues
« Reply #1 on: May 09, 2019, 09:07:00 PM »
Try Restore Defaults under the Setup tab  ...
If that doesn't work you may have a failing xducer  ...
Test your head unit on another xducer - or another head unit on your xducer  ...
Or call HB - 1-800-633-1468
Offline Fresnoron
« Reply #2 on: May 09, 2019, 10:53:49 PM »
I will try a reset in the am.....I have it networked with a 7" helix mega di...is there a way to test through the networking.
« Reply #3 on: May 10, 2019, 08:52:52 PM »
No sir  ... Testing a failing SI xducer needs to done by direct connection of another SI xducer to head unit with the ethernet disconnected  ...
Testing a DI unit on your SI xducer will not tell you anything because the DI unit (when testing as a stand alone unit) doesn't have SI views for verification  ...
Last post December 16, 2017, 09:21:09 AM
by bigkahuna
Last post February 19, 2018, 08:24:42 PM
by Whistler
Last post January 06, 2019, 02:05:37 PM
Last post February 06, 2021, 08:09:43 AM
by Bayou Basser
Last post July 14, 2022, 06:25:29 AM
by oschi
Last post August 20, 2023, 02:22:28 PM
by Michael S.
