Author Topic: 898c HD SI  (Read 6416 times)
Offline dkibat
  • Unit(s): 898SI
  • Accessories: Ethernet
898c HD SI
« on: October 13, 2018, 06:00:55 PM »
I am trying to enter coordinates Longitude & Latitude from the Missouri dept of conservation brush pile location while sitting in my yard, Using a LakeMaster chip of the lake with the fish icon installed by them i highlight the icon and show the info of it, Latitude & Longitude, The number's given don't match the MO dept number's so i try to correct and enter a new waypoint list using the Dept #'s for that brush pile but the number's don't go beyond 5 then they go back to 0 no option's for higher numbers. The chip will not let me change to a higher number although the ones's installed by them go higher. Could use a little help.
Was wondering if maybe i have to be on lake and actually locate pile with unit and then have the correct numbers?
Re: 898c HD SI
« Reply #1 on: October 13, 2018, 10:12:47 PM »
The default format for HB is Degrees, Decimal, Minutes such as dd°mm.mmm'
Are you changing the default Position Format (under the Setup tab) to the format that your data for the Missouri dept.of conservation is written in  ...??
« Last Edit: October 13, 2018, 10:21:02 PM by rnvinc »
Offline dkibat
  • Unit(s): 898SI
Re: 898c HD SI
« Reply #2 on: October 14, 2018, 11:20:32 AM »
THANKS FOR THE QUICK REPLY. I have not changed anything on the Bird, didn't realize it was different here is and example of the coordinates i am trying to enter they have 2 different ones
Longitude -93.319824 Latitude 37.899977
UTM-X 471882.1464 UTM-Y 4194765.5422
These are for a brush pile and the location they have for it. ( These are TOP SECRET ) so be careful with these. LOL.  I don't really have any experience with entering these and don't know what the second set are for.
Re: 898c HD SI
« Reply #3 on: October 14, 2018, 08:42:14 PM »
*Press Menu twice to get into the Main Menu System  ...
*Cursor over to the Setup tab  ...
*Cursor down to "Position Format"  ...
*Change the selection to dd.ddddd° (just leave off the last number in your string)
(Change format back to default dd°mm.mmm' if desired)  ...
Offline dkibat
  • Unit(s): 898SI
Re: 898c HD SI
« Reply #4 on: October 14, 2018, 10:06:17 PM »
OK  Thanks I will try that tomorrow, Thanks for the info Have a good week,  Thanks again. Dennis
Last post May 02, 2011, 05:44:33 PM
by Helge23
Last post June 01, 2011, 11:22:58 AM
Last post October 19, 2012, 07:49:11 AM
by RivRunR
by raypla
Last post June 05, 2014, 01:35:38 PM
by G3fisherman
Last post July 31, 2014, 11:11:07 AM
by zdriver
Last post August 05, 2014, 12:12:28 PM
by fishermanatr
Last post November 15, 2019, 02:31:02 PM
by Bahamasbroker69
