Author Topic: Solix units stopped networking  (Read 26529 times)
Offline Skeeter07
  • Unit(s): 1198 c si, 899ci hd si, 798ci si
  • Software: lastest
  • Accessories: none
« on: September 09, 2018, 07:09:38 PM »
Was out fishing and everything was working and then half way through day 360 stopped working and gps and sonar stopped being shared along with mapping not be shared.  5 port switch is under console everything was still plugged in but when networking issues started I was hearing ticking sound coming from under console.  Anyone thin 5 port went bad?  Is there a fuse for 5 port?  Low voltage?  Looking for help and all was wired from basscat factory.  Thanks.
Re: Solix units stopped networking
« Reply #1 on: September 10, 2018, 07:57:28 PM »
I would hope the factory wired power to the AS ETH 5XPG with a fuse  ...
Can you trace the the power wire to where they connected it to 12v power  ...??
Offline Skeeter07
  • Software: lastest
  • Accessories: none
« Reply #2 on: October 08, 2018, 09:23:50 AM »
So haven't taken boat in to get networking problem above checked out.  But went out yesterday and to my amazement 360 and units were linked again.  Nothing changed except deleting all nav data on each machine.  Anyone had this happen to them? Been told by humminbird they are working on another update for solix units.  Sure hope this helps with this and not having to finesse settings to get depth finders to work correctly.  Spend thousands of dollars to have these issues.  No wonder you see a lot of ppl going to Garmin and Lowarnce.
« Reply #3 on: October 08, 2018, 10:40:08 PM »
We have seen corrupt Nav data causing weird issues across many models  ...
Note if you edit waypoints: only use letters and numbers. Do not use spaces or special characters  ...
Offline Skeeter07
  • Software: lastest
  • Accessories: none
« Reply #4 on: October 09, 2018, 12:34:46 PM »
Thanks for the info Rickie.  Puzzling sometimes.
Offline hollada
  • Unit(s): Pair of Solix SI
« Reply #5 on: October 28, 2018, 10:43:45 AM »
I have hundreds of waypoints with spaces in the name.  I also have sporadic strange problems with my solix 12.  What kind of issues are traceable to spaces in a name?  Anyone know if HB is doing anything to address this?
Last post March 09, 2014, 02:49:44 PM
Last post April 03, 2015, 12:54:20 PM
by pescarul1
Last post December 25, 2015, 08:04:09 PM
Last post December 08, 2016, 08:52:40 PM
Last post January 23, 2017, 01:52:04 PM
by Mark Saikaley
Last post March 05, 2019, 08:59:39 AM
Last post November 04, 2023, 07:58:03 PM
Last post February 03, 2024, 10:05:27 PM
