Author Topic: Bricked Solix, please help if you can  (Read 13926 times)
Offline nrgbentall
  • Unit(s): solix,997
« on: August 26, 2018, 05:04:56 AM »
Having a slight problem with my Solix after performing an upgrade to 3.230 unit, after power on after a few minutes unit goes to this screen
Then crashes and reboots on this screen
Does anyone know of a recovery mode or bootstrap option on a Solix, or a way to transfer the operating software across from sd card / Nmea /ethernet.
Any help much appreciated
Nick
Re: Bricked Solix, please help if you can
« Reply #1 on: August 26, 2018, 10:26:58 PM »
The only advice I can give is to disconnect everything from the unit except power and xducer, remove any SD cards, and test on a known good power supply..
Here is some contact info  ...:
https://www.johnsonoutdoors.com/locations?id=127
Offline nrgbentall
« Reply #2 on: August 27, 2018, 03:31:30 AM »
Thanks for you suggestion. I have nothing connected to the unit except power, voltage is good.
I feel the unit must have a bootloader accessible at boot up as it's linux based, just don't know combination of buttons required to access it
Anyone have any further ideas? I'm based in the UK so not the easiest to return the unit to Humminbird
Thanks in advance
Offline DennyO
  • Unit(s): Ulterra Link Solix 15 & 12 G2 5 pin Hub
  • Software: 3.40
  • Accessories: Softw2.14 L, 2.04R
« Reply #3 on: May 04, 2019, 12:21:01 AM »
Did you have the ducer connected as well?
You said only the power cord was connected, I'm just asking here.
The Eyes have it! Hooking walleyes & watching Hawkeyes.
Offline Gimp
  • Unit(s): 998 HD SI
  • Accessories: i-Pilot Link
« Reply #4 on: May 04, 2019, 11:15:41 AM »
Voltage doesn't matter nearly as much as amperage. The Solix 15 is an amp hog. I'm betting this is an amp issue (i.e. battery, wire, wire connections, etc.)
Offline gunn
  • Unit(s): HUMMINBIRD Solix 12 Chirp MEGA SI+ G3
« Reply #5 on: June 15, 2022, 12:18:53 AM »
Have you found a solution to your problem? I have the same problem.
Offline varimas
  • Unit(s): Humminbird 899siHD
  • Software: 899ciHD_SI_v7_650
  • Accessories: HumminbirdPC 4.4.6
« Reply #6 on: July 15, 2022, 06:25:52 PM »
Contact PM
We can help.
Last post July 05, 2013, 10:35:25 AM
by ITGEEK
Last post January 25, 2018, 01:41:19 PM
by N9Phil
Last post February 11, 2018, 06:42:33 AM
by reso
Last post May 26, 2018, 10:33:59 PM
by D Johnson
Last post August 03, 2022, 07:20:15 AM
by Jopple
Last post April 18, 2018, 08:09:56 AM
by danlaboucane
Last post May 04, 2018, 09:59:22 PM
Last post August 09, 2018, 04:54:51 PM
by Diesel Pro
