Author Topic: 1197 Firmware Download - Current and Previous Versions  (Read 30224 times)
« on: April 15, 2009, 10:16:16 PM »
Now you can download previous Software/Firmware Updates for your SI unit.  Visit the Software Download Section for updates.  You will need to be logged in to view the Downloads.
Software Downloads
Offline AHL
  • Unit(s): 1197
  • Software: 4_750
Re: 1197 Firmware Download - Current and Previous Versions
« Reply #1 on: September 23, 2009, 05:37:51 PM »
hi, Just a heads-up for anyone who is going to update FW on the 1197.
I think (well this is my assumption) that safest way of doing a FW upgrade is by using the memory card and not the humminbirdPC. I got stuck halfway with an error message saying "firmware error". It took a number of attempts and couple of pretty stressful hours until I finally could get the 1197 connect to the PC while at the same time having the test menu open on the screen of the unit (which seems to be the only way to go) and got the original FW version loaded. Eventually I used the memory card for upgrading to 4.570 and that worked just great.
So lesson learned, never use the humminbirdPC for upgrades..
Offline Peter
  • Golfe de Frejus - BYMS 22
    • Oxygen for Digital Diving
  • Unit(s): 1197c Si and Solix 16
  • Software: 4.750
  • Accessories: A boat !!!
« Reply #2 on: June 09, 2010, 01:57:18 PM »
Hello AHL,
Nasty experience I must say.  I had a problem with HumminbirdPC too. But I solved it. Afterwards, uploading the new firmware (4.750) went smoothly.
I don't know if you are using an USB2Serial interface. If you do then have a look at "Configuring the serial port to set up communication with HumminbirdPC" (http://forums.sideimagingsoft.com/index.php?topic=1289.0). HumminbirdPC even didn't see the unit. Now everything is OK.
An interesting feature of HumminbirdPC is the "Customize Personalized Text" icon. Applying this icon you can enter text that will appear in the middle of your Humminbird screen each time you power up. You have 4 lines of text at you disposal where you can enter for example your name, home port, company name, name of the vessel, ...
Regards, Peter
« Last Edit: June 09, 2010, 02:07:46 PM by Peter »
Last post April 15, 2009, 10:17:27 PM
Last post June 11, 2009, 11:18:07 AM
Last post May 05, 2009, 09:41:16 AM
Last post April 15, 2009, 10:19:27 PM
Last post August 26, 2010, 01:56:54 AM
by ElvisMarcy
Last post April 09, 2013, 09:42:05 AM
by wolfs4evr
Last post February 04, 2013, 09:16:16 AM
Last post March 24, 2014, 01:51:13 PM
