Author Topic: Sun & Moon info in latest software update 1.640  (Read 11920 times)
Offline mako9man2
  • Unit(s): 999ci HD SI
« on: June 30, 2018, 08:17:40 AM »
I updated my Helix 12si software to this latest version 1.640 and noted one of the changes was this Sun & Moon information.  Where does this appear and on which screen(s)?
Offline N9Phil
Re: Sun & Moon info in latest software update 1.640
« Reply #1 on: July 05, 2018, 10:10:18 AM »
I don't have a Helix but the solix has a tool bar on the main screen and you can access the info from that menu.  Other than that I would probably recommend going through every screen until you find it.  Good Luck and when you do locate the location please post it on the site for others that run into the same situation.
Offline mako9man2
« Reply #2 on: July 05, 2018, 02:44:04 PM »
I found the Sun & Moon update.  On the Helix you must turn the display to BOXES.  Then go to a box and cycle through the options for ..Temp...Volts...Speed etc.  The Sun info will appear as one of the options.  Still not sure what it does other than give you the actual Sunrise and Sunset times.   I was under the impression that there was Moon phase information as well.
Offline Whistler
  • Unit(s): 1198c SI, 1199ci, Helix 12 SI G2N
  • Software: 7.510,7.460,1.460
  • Accessories: Heading Sensor, NMEA
« Reply #3 on: July 06, 2018, 06:35:56 AM »
Would be awesome if they tied this to tidal/major/minor info based on gps location.  I have a Casio fishin' time watch that provides alarms for the daily major/minor and it would be great to have that functionality on the graph.
Offline N9Phil
« Reply #4 on: July 06, 2018, 02:22:12 PM »
I would also think that you would have to have a good gps signal  to get the moon cycles.  The Solix screen has both the sun info and then it shows the dates of four moon phases.   As I remember my 1198 had to have I believe a menu set to advanced or something like that to get all of the menu screens to show up.  I can't  check that as the 1198 was given to my Grandson.
« Last Edit: July 06, 2018, 02:27:17 PM by N9Phil »
Last post March 31, 2011, 02:19:51 PM
Last post May 16, 2011, 02:31:33 PM
by Del
Last post August 25, 2011, 10:46:40 AM
Last post March 05, 2013, 04:56:48 PM
by Charger176
Last post August 14, 2014, 08:12:15 AM
by Beaulieu80
Last post March 02, 2015, 03:09:31 PM
Last post August 07, 2015, 09:32:34 PM
Last post June 01, 2016, 08:46:10 AM
