Author Topic: Boat icon does not move with heading indicator?  (Read 15991 times)
Offline dtpac
  • Unit(s): 898, 1197
« on: June 17, 2018, 08:47:14 AM »
Recently my 998c SI navigation started acting up. The boat icon remains fixed and does not follow the heading indicator. If i move the puck then the boat icon will move on the screen. However when I'm traveling the heading indicator varies  around the boat as i travel. The boat icon use to follow the heading indicator. I have the latest update. I have reset defaults. I have over 5000 hrs of use and feel like I have looked for any possible fixes without any luck.
Anybody have any ideas?
Re: Boat icon does not move with heading indicator?
« Reply #1 on: June 18, 2018, 11:06:16 PM »
Is this with the AS GPS HS antenna  ...??
Offline dtpac
« Reply #2 on: June 18, 2018, 11:37:52 PM »
It is with the AS heading indicator.
« Reply #3 on: June 19, 2018, 01:21:39 PM »
Did you test the mounting area for magnetic interference  ...??
See this video  ...
Offline dtpac
« Reply #4 on: June 19, 2018, 09:08:50 PM »
It was working great, Just froze up.. Its mounted on top of my t top. I will check around it to see if anything changes.??
Thanks for the though.
Offline dtpac
« Reply #5 on: September 24, 2018, 09:04:51 AM »
Moved antenna, still no change.
« Reply #6 on: September 24, 2018, 09:14:07 PM »
It sounds as if the AS GPS HS antenna may be failing  ...
Do you have access to another unit you could test connected to your AS GPS HS antenna  ...??
Offline dtpac
« Reply #7 on: September 25, 2018, 09:17:03 AM »
I do, Gonna try it next month.
Last post July 24, 2011, 11:15:15 AM
by gofission
Last post March 06, 2012, 10:26:50 AM
by Double Digit
Last post April 18, 2012, 11:22:59 AM
by Staafe
Last post June 25, 2013, 07:28:01 AM
by TroyBoy30
Last post May 29, 2014, 08:32:14 PM
by N9Phil
Last post May 18, 2014, 07:59:29 PM
by Scrutch
Last post March 02, 2015, 04:06:53 PM
Last post March 28, 2016, 02:01:11 PM
by bobcoy
