Author Topic: Question on Ultrex and 1199  (Read 14411 times)
Offline Boots
  • Unit(s): 998,788, purchasing twin 1199's
  • Software: NA
  • Accessories: Thru Hull trans??
« on: January 20, 2018, 09:17:58 AM »
Just purchased a Ultrex an wondering if the follow the contour will work with the 1199, and route and waypoints ::) ::) I purchased for the spot lock the Ultrex is linked to the Bird 1199 on the from with SI, DI transducer on lower unit of trolling motor.  Thanks
Re: Question on Ultrex and 1199
« Reply #1 on: January 20, 2018, 09:36:04 PM »
If the Ultrex is the iLink model, then you will need an iLink capable LakeMaster mapping product for Follow the Contour (LakeMaster regional, Chart Select, AutoChart PC created mapping, AutoChart Live)  ...
https://www.humminbird.com/Category/Technology/i-Pilot-Link/
Offline Boots
  • Software: NA
« Reply #2 on: January 21, 2018, 08:56:11 AM »
Thanks I add the Lake Master to the wish list, using Navanotics Card from and rear at this time.  So they won't works :'(
Offline Boots
  • Software: NA
« Reply #3 on: January 21, 2018, 07:42:41 PM »
There no question the Ultrex is the finest thing since the first trolling motor on earth ;D Love everything.  The only problem I have :-* I the front 1199 is almost usless except for GPS. When Ultrex on the you can not see the bottom in DI and All Snow on the 2D.  Never had the problem with the the Fortrex 112 I took off the boat. Yes some minor on High Speed.  Love the Ultrex but got to the the snow off the screen.  Front 1199 is totally useless with trolling motor ingauged and running.  That Sucks ::)
Offline Boots
  • Software: NA
« Reply #4 on: January 21, 2018, 07:58:57 PM »
Help Help did not have this with the Fourtrex I replace with this motor. Yes linked to front unit. ::) ::) ::) ::) Not a Happy Camper :-[ :-[
« Reply #5 on: January 21, 2018, 09:00:33 PM »
Humminbird should be your 1st call for dealing with interference  ...
They deal with customer's interference issues every day  ...
1-800-633-1468
Offline Boots
  • Software: NA
« Reply #6 on: January 22, 2018, 08:09:56 AM »
Will do, I am waiting for the dealer to open. They are Minn Kota warranty and repair stations from whom I purchased it.  Reading all the fix's this site also. Thanks
Offline Boots
  • Software: NA
« Reply #7 on: January 22, 2018, 08:46:20 PM »
At the Dealer all day, changed transducers SI/DI, updated all software ,rewired, cussed and discussed with HB via phone. Told got to put it in the lake to test.  ::) Told got to Lake Test, well it will be done.  I hope it's fixed. Will report. Front HB 1199 will NOT work on on Ultrex with DI/SI transducer..  Same Same Sonar Co/ Same same TM company ;)
Not a happy camper,  ::) No problem with same 1199 and Fortrex 112 with SI/DI
Offline Boots
  • Software: NA
« Reply #8 on: January 24, 2018, 08:35:13 AM »
Well the boy's at The Great Outdoors got it healed ;) two of the best worked on it 4 hours, put on new SI/DI ext transducer :o, updated the software ;D which I don't do as much as I should due to if it's working right don't fix something that's not broke :D :D :D, check all grounds from inside the motor, to the top, back to the rear cranking battery.  They did not feel it was fixed, nor did I.  Humminbird Tech told em it's got to be in the lake to test.  Well big cigar to him, once back on the lake it's 100% spot on, zero snow or lines even on #10 speed. All the line gone when the pedal was moved even with motor not running. Big Hand to "The Great Outdoors" service crew  ;D ;D that's I buy most of my mess from them and they service what the sell.
Offline hoffa09
  • Hoffa09
  • Unit(s): 898, 788c, 728
« Reply #9 on: May 01, 2019, 04:29:20 PM »
It will.  cool feature and your adjust off the contour line left or right by +/- ft
Last post March 17, 2014, 11:56:17 AM
Last post September 24, 2014, 11:26:17 AM
Last post May 06, 2015, 05:20:22 PM
Last post March 04, 2016, 07:01:07 PM
Last post April 22, 2016, 10:01:38 AM
by NitroFish
Last post July 19, 2016, 11:31:26 AM
Last post March 03, 2017, 10:55:06 PM
Last post July 08, 2024, 11:19:39 AM
by Mpierce1174
