Author Topic: 798 transducers  (Read 6152 times)
Offline tblshur
  • Unit(s): 798ci hd si
  • Software: 7.120
798 transducers
« on: November 21, 2017, 06:36:37 PM »
curently i have a 798ci hd si di . 83 and 200 khz .would it be worth the money to get a xnt 9 di t transducer to get the 455 khz and what does that help im not very knowledgeable about this. or would it be better to put this money toward an upgrade in ff thank you all very much for any responce :)
Re: 798 transducers
« Reply #1 on: November 22, 2017, 09:01:25 PM »
The 798 came stock with the XNT 9 SI 180 T which has 83/200kHz 2d and 455kHz SI  ...
The XNT 9 DI T is for HB DI units  ... It has 200/455kHz 2d and 455/800kHz DI  ...
There is no Menu selection in the "Transducer Selection" Menu under the Sonar tab for the 798 to transmit the correct frequencies for the XNT 9 DI T  ...
The only upgrade xducer for the 798 would be the XHS 9 HDSI 180 T  ...which would give somewhat better SI because the piezoes are longer creating a thinner SI pulse for better detail in the SI image  ...
https://www.humminbird.com/productDetail-Accessory.aspx?Pageid=728&id=1160
« Last Edit: November 22, 2017, 09:02:27 PM by rnvinc »
Offline tblshur
  • Software: 7.120
Re: 798 transducers
« Reply #2 on: November 23, 2017, 09:09:40 AM »
rnvinc thank you very much for your quick responce i will be looking to get one if they go on sale. thks again and happy thanks giving
Offline tblshur
  • Software: 7.120
Re: 798 transducers
« Reply #3 on: November 23, 2017, 09:51:58 AM »
rnvinc ,i just looked at hummingbird.com online and it says the xhs9 hdsi 180 t goes on the 800 and up series of fishfinders if i read it correctly. thanks for your help
Re: 798 transducers
« Reply #4 on: November 23, 2017, 07:49:40 PM »
The HDSI transducer comes standard with the 800 and up series, but can also be used on the 798 as an upgrade.  It won't get you the 800Khz frequency but will give you sharper images at 455 than the compact transducer that comes with the 798.
Offline tblshur
  • Software: 7.120
Re: 798 transducers
« Reply #5 on: November 24, 2017, 08:47:41 AM »
BobB thank you very much , thats what i wanted to hear . i'll be looking for HDSI i want an upgrade just trying to decide how to get the best bang for the buck thanks again for your time . :)
Last post September 15, 2012, 07:43:00 PM
by Justins
Last post December 13, 2012, 11:14:10 AM
Last post April 15, 2013, 12:34:06 PM
Last post May 14, 2014, 03:09:53 PM
Last post October 14, 2014, 07:17:29 AM
Last post September 19, 2014, 10:11:37 AM
Last post September 17, 2014, 11:42:07 PM
by theoryofwi
Last post November 05, 2014, 01:59:52 PM
by dae06
