Author Topic: Need help with Matrix97: GPS and update problems  (Read 24483 times)
Offline kkt_mag
  • Unit(s): Matrix97
  • Software: 2.50
  • Accessories: GR4
« on: June 20, 2017, 10:18:52 AM »
I inherited an old fishing boat with a Matrix97 GPS/fishfinder and GR4 puck (e.v. very old).  The GPS stopped working soon after my taking over the boat.  Sonar works fine.  When I run a system test on the startup screen, the GPS shows as “not connected.”
I’ve double checked the connections in the back of the unit – very solid.  No corrosion showing.
Voltage in the powercable at the pins is +12V by multimeter, although the Matrix97 shows it to be 11.2 volts on system test.
I connected it directly to a separate battery – same result: +12V by multimeter and 11.2V reported by Matrix97.
I checked the pigtail on the GPS cable:  +11V between the red and black wires (e.g. 1 volt drop in this output compared to the voltage into the Matrix97 as measured at the powercord).
I’ve restored defaults à no effect.
I purchased 2 MMC cards (8MB) and downloaded the update file from myhumminbird.  (These MMC cards are hard to find these days.)  The latest software version for  Matrix 97 is Version 4.750; Release Date: 01/14/2010.  The file I downloaded is entitled, “0bee626c78544848909f28c6b364bd96 (1).bin”  I used HumminbirdPC to put this file onto one of the 8MB MMC cards, and I used my Windows 7 PC to put this same software on the other MMC card.  When I put either of these MMC cards into the MMC slot in the Matrix97, the unit does not automatically update.  It does not matter whether I put it into the slot after the unit is powered on, or before it is powered on, or whether the unit is in “system test” or ”simulator” or “normal mode.”  And no dialogue box comes up indicating the unit recognizes the card/software.  And the menu button does not provide any option for “update software.”  I did use the menu button to “restore defaults.” I don’t have an AS-PC3 cable. They are about $50 on line.
For the possibility that the voltage out to the GPS is inadequate, I checked the voltage at the hole for pin 1 in the back of the Matrix 97.  It reads 10.8 volts (although keep in mind that the power in reads 11.2 even though power in at the cable is +12V).  So I carefully opened up that cable just before it enters the puck, and divided the red (power) wire to supply true +12V to the puck from a separate battery (grounded to black).  GPS still doesn’t show up as connected on the Matrix97.
It is frustrating to not be able to update the software to see if this could fix the problem (though deep down, I don’t think this is likely).  Does anyone have any clues why I am unable to update the software via the MMC card?   And as mentioned, I don’t have an AS-PC3 cable.
I could replace the puck with a GR16 for ~$125 – but if this doesn’t fix the problem, I’ve probably wasted another ~$125 since the GR16 puck seems outdated and not used on current Humminbird units.  Do these pucks go bad frequently?
If I can’t fix this one, since all of the components are old it seems that I would have to purchase new head unit and new GPS puck, new transducers, new Navionics data cards; and then re-run cable for the new transducers, etc.  At lot of $$ and time. Or, can you recommend one that is currently available that would be backwards compatible with any of this existing old equipment (e.g. the transducers or Navionics data on MMC cards)?
I do appreciate your time reading through  my note in hopes of providing help. Thank you.
Re: Need help with Matrix97: GPS and update problems
« Reply #1 on: June 20, 2017, 02:15:01 PM »
If you are reading 11.2V on the unit, you have a bad connection somewhere that is causing voltage drop under load.....could be the power connector on the back of the unit, or somewhere else in the wiring.  GPS is one of the first things affected by low power.
Offline kkt_mag
  • Unit(s): Matrix97
  • Software: 2.50
  • Accessories: GR4
« Reply #2 on: June 20, 2017, 05:10:32 PM »
Thanks, Bob B.  The boat is sending 12V to the Matix97 head unit:
Voltage in the powercable in to the Matrix97 at the pins is 12V by multimeter.  However, despite this the Matrix97 reports a voltage of 11.2 volts on system test.  And even when I connected the Matrix97 directly to a separate battery I observe the same result: 12V input as measured by by multimeter, but only 11.2V reported by Matrix97.  Seems to me that the multimeter is the gold standard -- is it meaningful that the Matrix97 reports 11.2 volts when the input is actually 12V?  Does this mean that the unit indeed is shot?  And a few other questions as mentioned below.  THank you.
« Reply #3 on: June 20, 2017, 05:21:55 PM »
Did you measure the voltage with the power cable unplugged from the unit ..... or plugged into the unit with the unit powered on?
Even if the voltage is checked external to the unit at the power plug with the unit powered on, if there is a bad connection at the power cord into the unit, you can still get voltage drop at the plug..... The unit is telling you you it is getting low voltage.
« Last Edit: June 20, 2017, 05:25:36 PM by Bob B »
Offline kkt_mag
  • Unit(s): Matrix97
  • Software: 2.50
  • Accessories: GR4
« Reply #4 on: June 20, 2017, 06:05:25 PM »
I checked the voltage in the power cable with the cable NOT plugged into the unit (and read the multimeter reads 12V).  How can I check the voltage in the power cable with the cable already plugged into the head unit?  With the cable plugged in, there is no immediate access to the pins in the cable.  I suppose I can open up the back of the unit and have access to the pins that come into the unit even when the power cable is plugged in.  Is that your suggestion?  Again, thank you very much.
« Reply #5 on: June 20, 2017, 06:30:43 PM »
I'm not familiar with the matrix unit, but on other core units if the cable collector is removed so there is full access to the power cord, there is access to the pins on the side of the plug.  If it's possible to check the voltage there, it would determine whether the bad connection is at the unit or somewhere else in the power feed.
When there is no current draw on the cable the voltage will normally check OK even when there is a bad connection since there must be current flow for the voltage drop to show up.  On some of the core units, the pins on the power cord can be tweaked VERY slightly to give a better connection in the socket.
You might be able to wiggle the power cord slightly while watching the voltage reading on the unit to see if the bad connection is at the unit.....The unit should be reading over 12V if the power feed is good.
« Last Edit: June 20, 2017, 06:33:24 PM by Bob B »
Offline kkt_mag
  • Unit(s): Matrix97
  • Software: 2.50
  • Accessories: GR4
« Reply #6 on: June 20, 2017, 08:28:19 PM »
I opened up the back of the unit and used alligator clips to positive and negative to provide power INSIDE the unit; this take the connector out of the equation.  And I confirmed 12.2 V battery on separate multimeters.  Even with this setup the Matrix97 reports it has 11.2 V on the System Status screen.  This is with no transducer or GPS connected (i.e. no extra current draw). And when I instead connect yet a different battery (Die Hard jump start battery) with 13.2 volts, the Matrix97 reads out that it has 12.2 volts -- agaiun about 1V less than what I am providing to the unit.
And even with the Matrix97 reporting that it has 12.2 volts, it won't automatically update the software when I plug in the MMC card with version 4.750.
Still looking for ideas as to why this unit won't update, and why it doesn't see the GPS puck.  Thank you all very much.
« Reply #7 on: June 20, 2017, 08:54:01 PM »
That's really odd .... kinda sounds like something is wrong inside the unit.
« Reply #8 on: June 20, 2017, 09:43:18 PM »
I understand there were some Matrix units that were old enough to only be able to update with the PC connect cable   ...
You should call HB to verify the proper update procedure for your Matrix  ...
1-800-633-1468
Remove the black cap off the GPS cable pigtail and make sure none of the wire ends are touching  ...
Here is some info  ...
http://forums.sideimagingsoft.com/index.php?topic=7362.0
Offline kkt_mag
  • Unit(s): Matrix97
  • Software: 2.50
  • Accessories: GR4
« Reply #9 on: June 20, 2017, 10:55:18 PM »
Thank you. Yes, I have taken the black cap off from the pigtail and confirmed that there are no shorted wires. And I have measured voltage between the red and black wires in the pigtail and detected 10.5 volts (though it ranges from 10.2 volts to 11.2 volts using a multimeter).   Second, in the off chance that voltage output to the GPS was too low for it to operate, I opened up the cable and spliced wire into a separate battery to ensure true +12 V to the GPS, but this had no impact -- the unit still did not detect the GPS.
In absence of some more helpful suggestions, it seems that I have the options of
1) buy a refurbished AS GR16 GPS receiver ($125) and hope that the problem is that the GPS went bad
2) buy a AS-PC3 cable ($60) in hopes that this will allow updating of the software in hopes that the software is the reason that the unit does not detect the GPS
3) buy a new GPS/fish finder (any suggestions on Humminbird unit that would be backwards convertible with the existing transducers and the old Navionics MMC cards?
I would go with (1) or (2) if folks feel that either of these are LIKELY the culprit.
Again, many thanks to all for even reading this, let alone for your suggestions
« Last Edit: June 21, 2017, 07:11:12 AM by kkt_mag »
Offline kkt_mag
  • Unit(s): Matrix97
  • Software: 2.50
  • Accessories: GR4
« Reply #10 on: June 21, 2017, 07:12:39 AM »
Sorry for the previous, garbled response (poor choice to try to respond using my iphone).  I have since made corrections in that previously garbled response.
« Reply #11 on: June 21, 2017, 02:43:37 PM »
If you could find someone else close to test your unit with their GPS, that would be an cheap way to find out if your unit is toast.....It still bothers me that your unit is showing low voltage.  I suspect a problem in the unit.
If budget is a concern, you could watch some of the used forums and pick up a nice unit for less money and maybe even expand your horizons in a SI unit.....PM me if you are interested in links to a couple used forums.
« Reply #12 on: June 21, 2017, 09:09:50 PM »
A call to HB will help determine the proper procedure for updating your Matrix  ...
1-800-633-1468
And they may also be able to offer advice on the voltage issue Bob is mentioning  ...
« Reply #13 on: June 22, 2017, 12:34:02 AM »
I just had another thought ...... if you connect nothing to the unit but power, do you still have the low voltage reading on the unit.....It is possible the GPS antenna itself is somehow dragging down the power in the unit.
Last post June 16, 2010, 11:11:39 AM
Last post April 12, 2011, 09:49:52 PM
by bmann
Last post July 02, 2012, 01:30:47 PM
by Patty
Last post March 08, 2012, 06:29:06 AM
by alnash
Last post April 09, 2012, 04:35:51 PM
by LittleGazoo
Last post April 30, 2014, 12:44:06 PM
by doug
Last post May 26, 2016, 12:33:00 AM
by speeedman
Last post May 31, 2016, 10:10:54 AM
by Tamnud
