Author Topic: GPS Wiring - 797C2 SI and AS GR16  (Read 17039 times)
Offline not2shabby
  • Unit(s): 797c2 SI
  • Accessories: AS GR16, XNT 9 SI 180 T
« on: March 24, 2017, 09:36:46 AM »
I bought my first boat on Sunday.  So, naturally, the troubleshooting has already started.  I'm new to HB and SI, so I'm open to all feedback you might have!  If I'm using the wrong jargon or running in the wrong direction, let me know.
Here's what I'm working with:
Head unit = 797c2 SI
External GPS = AS GR16
Transducer = XNT 9 SI 180 T
Here's my issue:  The previous owner damaged the connector on the end of the cable from the AS GR16 to the head unit.  After damaging the connector, he cut it off.  Now I have an AS GR16 cable running to my head unit, but no connector on the end to make the connection.
Here's what I think I might be able to do to fix it:  Can I buy the y-cable (AS YC), cut one of the male connectors off, wire the cable from the AS GR16 to the leg of the AS YC, and connect the AS YC to the head unit?
Will this work?  If no, is there another solution or do I need to buy a new GPS Antenna?  If yes, will the wiring colors match?
Any/all feedback is more than welcome!
Offline diver651
  • Unit(s): 1197, 1198
  • Software: 6.47
  • Accessories: Interlink, Aux Speed/Temp,
Re: GPS Wiring - 797C2 SI and AS GR16
« Reply #1 on: March 24, 2017, 01:24:07 PM »
not2shabby,
You can wire a new end on the GPS you have, but you need to be careful as to what cable you try to get your new plug from. Not all cables have all of the pins wired, depending on what is intended to be connected. I know that I have used the wye cables (the ones that come with the GPS units and are intended for splitting out the accessories connections) to make adapters to connect the Humminbird GPS units to my computer. If you do not mind having the extra pigtail hanging off, those will work fine. Otherwise a GPS extension cable would also be a good option.
What part of the country are you in? I may have a couple of those with the GPS connection plug cut off that would suit your needs. If so you are welcome to one.
Offline not2shabby
  • Unit(s): 797c2 SI
« Reply #2 on: March 24, 2017, 01:36:16 PM »
Mike,
Thanks for the reply.  I'm located in Corpus Christi, TX.
I was reading the 797c2 SI manual and it mentioned a GPS extension cable, but I was not able to find one on the HB website.  What's the part number?  Which pins are wired on the original plug for the GPS antenna?
Again, thank you!
Jason
« Reply #3 on: March 24, 2017, 10:25:44 PM »
The NMEA COM leg of the AS YC (smaller of the 2 wires) has the correct wire colors to match the wire colors in the GPS cable ...
The only difference I could find when I cut the end off the AS YC and opened my AS GPS HS antenna is the ground is bare wire in the AS YC ... and the ground in my model AS GPS HS antenna is black ...
The pinout for the AS GR16 shows ground as bare (like in the AS YC) ...
If using the AS YC for splicing onto an external GPS puck - it may be a good idea to break the center pins (#3 pin and #4 pin) off ...  as these 2 pins are the yellow and orange wires that go to the ASSY COM leg of the AS YC...and are not needed anyway for the external GPS antenna ...
And another note to consider ...:
The power pin (pin #1) is shared into the ASSY COM leg of the AS YC ... So be aware of this if the connector on ASSY COM leg is removed ...
« Last Edit: March 25, 2017, 08:58:38 AM by rnvinc »
Offline not2shabby
  • Unit(s): 797c2 SI
« Reply #4 on: March 27, 2017, 01:00:16 PM »
Rickie, that's exactly what I needed.  Thank you SO MUCH for helping me out.
-Jason
Offline not2shabby
  • Unit(s): 797c2 SI
« Reply #5 on: March 29, 2017, 03:10:20 PM »
Just one question about pins 3 and 4.  If I don't break them off, will they interfere somehow?  And if I really should break them off, what is the best method to do that and avoid damage to the remaining pins?
Thanks!
« Reply #6 on: March 29, 2017, 09:11:09 PM »
Thanks!
I don't expect there would be any harm in leaving pins 3 & 4 as long as the ASSY COM leg of the AS YC is left intact ...
Breaking a pin is as easy as bending in one way and then the other ...They will usually break off with the 2rd or 3rd bend ...
Last post October 24, 2009, 09:43:22 PM
Last post March 12, 2010, 04:02:44 PM
by soretoe
Last post May 27, 2010, 09:30:57 PM
Last post January 28, 2011, 01:15:49 PM
Last post February 10, 2012, 08:12:53 AM
Last post February 04, 2013, 11:15:31 PM
by johnca51
Last post August 29, 2014, 03:18:04 PM
by Tom Wolter
Last post July 05, 2015, 03:23:42 PM
by Monty
