Author Topic: 360 Imaging  (Read 7433 times)
Offline 1fisherofmen
  • Unit(s): 998ci
  • Accessories: ipilot
360 Imaging
« on: December 14, 2016, 09:44:31 PM »
I have a 998c SI combo W/ GPS. I recently picked up a 360 imaging unit. This 360 comes with a GPS receiver/heading sensor as did the 998. Do I really need both GPS receivers mounted in my boat?
Re: 360 Imaging
« Reply #1 on: December 14, 2016, 11:16:14 PM »
If you only have the 1 unit ..... just use the HS GPS.
  • Unit(s): 998ci
Re: 360 Imaging
« Reply #2 on: January 03, 2017, 07:50:04 PM »
thanks Bob, and sorry for the late response! I'll be hooking things up some time this spring. Thanks again. I have another concern, my 998 has only 1 Ethernet port and I have a terrova connected to it. I've seen hummingbird has an e-switch but I don't know about these things. Will I be able to see both the terrova and the 360 on my control head through this switch?
Re: 360 Imaging
« Reply #3 on: January 03, 2017, 07:59:28 PM »
Yes all devices can talk to each other with the switch......You connect the Ethernet cable from all your devices to it....If you have more devices than 1 switch can handle .... you can add more.
http://www.humminbird.com/Products/AS-ETH-5PXG/
  • Unit(s): 998ci
Re: 360 Imaging
« Reply #4 on: January 07, 2017, 08:36:11 PM »
Awesome, Thank you.
Last post October 18, 2012, 11:19:31 AM
Last post November 26, 2012, 11:35:51 PM
by Wylezalek
Last post November 17, 2013, 08:50:09 PM
Last post October 26, 2015, 09:34:42 PM
