Author Topic: Problems with Onix 10, Onix 8, 1198  (Read 31631 times)
Offline bassleo
  • Unit(s): ONIX10-ONIX8_1198CHOsi
  • Software: Onix(2,7)1198(6,67)
  • Accessories: watersense,switch AS ETH 5PXG
« on: November 17, 2016, 04:12:50 PM »
Hello, I’m Leonardo from Italy and I’m writing to you for the problems I’ve encountered with my bass boat 2012 Nitro Z8.
After updating all the tools, resetting the ethernet network and checking the tools one by one, I’ve found the following problems:
- Onix 10 bow: the transducer was mounted on a Motorguide IX5. Every time I push the button to start the electric engine the monitors shows vertical lines, thus this is a clear problem of noise created by the engine.
- Onix 8 side console: it presents the Onix 10’s problem if it is connected to the ethernet network.
Another problem rises with the stern transducer directly connected to Onix8, both with and without ethernet connection. After the first test without ethernet connection, after moving with the engine the transducer shows a depth of 1900 meters, then 3590 meters, then 9540 meters and so on. The only way to make it work properly is to reset the transducer setup; however it works until the next navigation.
I have the same problems also with the latest Onix software update (Version 2.700) and 1198 (Version 7.670).
The ethernet connection was tested both with switch AS ETH 5PXG and directly between the tools.
You can find attached the pictures of the stern transducer
Re: Problems with Onix 10, Onix 8, 1198
« Reply #1 on: November 18, 2016, 12:38:42 PM »
1. Trolling motor interference is a common discussion on the forums ...
Read this and follow the steps mentioned ...and then post back if there are still RFI issues ...
http://www.humminbird.com/Category/Support/FAQ/Trolling-Motor-Interference/
2. Ethernet connected units can experience RFI thru the Ethernet cable from another affected unit ... hopefully this issue will go away when the RFI issue in point 1 above is remedied ...
3. The erratic depth readings when the engine is engaged is most likely turbulence created by your prop ... Sonar cant read Thru bubbles ...
This sometimes can be remedied by moving the xducer away from the turbulent water ... (your pic of the transom mounted xducer did not post where we can offer advice on placement ... or did you post the pics in a different sub-forum? ...) ...
« Last Edit: November 18, 2016, 12:41:06 PM by rnvinc »
Offline bassleo
« Reply #2 on: November 22, 2016, 01:55:23 PM »
Hello
here are the pictures of the transducers on my boat Nitro Z8
« Reply #3 on: November 22, 2016, 08:25:10 PM »
My guess is still turbulence created by the prop ...
Are the depth readings correct up until a certain speed is reached ... or do depth readings become erratic as soon as the prop is engaged ...??
Another observation with the ONIX SI xducer and 1198 SI xducer side by side ... :
Are you getting right SI blockage in the ONIX SI image ...and left SI blockage in the 1198 SI image ... ??
« Last Edit: November 22, 2016, 08:26:13 PM by rnvinc »
« Reply #4 on: November 22, 2016, 08:28:07 PM »
Also ... are any of the remedies for trolling motor RFI in the link I provided working for your interference issues ... ??
Offline bassleo
« Reply #5 on: November 23, 2016, 01:35:24 AM »
hello, I unplugged transducer from 1198 (off) but ONIX reading continues to give me different depths 780 ... 860 ... 910 ... 1050 .... etc but when I turn off the prop and get ready to fish the transducer seems crazy and to make it work again I have to reset it.
« Last Edit: November 23, 2016, 01:11:51 PM by bassleo »
« Reply #6 on: November 23, 2016, 08:06:54 PM »
To get the troubleshooting down to its basic Setup ... you can try disconnecting the networking completely and test the ONIX by itself with nothing else powered on ...
Also try resetting defaults - 1st try resetting Sonar defaults ... if that doesn't help try complete Restore
defaults ...
Offline bassleo
« Reply #7 on: November 24, 2016, 02:01:47 AM »
the test of ONIX alone was made ....... but the result was the same  ??? ???
LEO
« Reply #8 on: November 24, 2016, 07:58:40 PM »
Is the ONIX depth stable if the big motor is not running and the boat adrift ...??
Offline bassleo
« Reply #9 on: November 25, 2016, 02:00:54 PM »
no, it is not stable..........
« Reply #10 on: November 25, 2016, 09:49:15 PM »
Here are some possibles steps ...:
*Restore Defaults ...
*Turn off SI and DI transmitters and test with only 2d transmitting ...
*Confirm xducer face is level with water's surface ...
*Confirm xducer and xducer cabling are not damaged ...
*Test with replacement ONIX xducer ...(if your ONIX is under warranty HB may send you one) ...
*Test your ONIX head unit on someone else's boat ...
*Test with 1198 xducer connected to ONIX (would need the AD 1429 adapter cable http://www.humminbird.com/Products/AD-1429/ ) ...
*Test with ONIX xducer and 1198 xducer using AS SIDB Y cable http://www.humminbird.com/Products/AS-14-SI-DB-Y/ (would also need AD 1429 listed above) ...
It sounds like the 2d piezo in the ONIX xducer is not functioning correctly ...
« Last Edit: November 25, 2016, 09:52:33 PM by rnvinc »
Offline bassleo
« Reply #11 on: December 03, 2016, 04:36:20 AM »
I've have done all the steps listed above. The only thing that is left to do is to completely reset the ONIX, I have been told that the only way to do it is by connecting the onix to a computer. Is it right? if yes, which cable should I use?
« Reply #12 on: December 03, 2016, 08:13:28 AM »
This is the procedure for ONIX hard reset ... (this will put the unit back to its original software version and erase any personal data) ...
In quick succession ...:
*Press and hold check -
*Press and hold x -
*Press Power -
*Release all 3 ...
Have you talked to anyone at HB about your issues ...??
« Last Edit: December 03, 2016, 08:15:31 AM by rnvinc »
Last post May 07, 2014, 04:27:24 AM
by Nitro78
Last post July 01, 2014, 02:12:18 AM
by Nitro78
Last post July 14, 2014, 09:38:42 PM
by CarolC
Last post November 13, 2014, 08:16:31 AM
by lcookie
Last post March 23, 2015, 11:28:33 AM
by metalworx
Last post May 30, 2015, 09:51:41 PM
by RonnieB
Last post May 19, 2015, 07:05:18 AM
by Vinniez520
Last post February 29, 2016, 09:54:06 PM
