Author Topic: 898c si CCFL to led upgrade?  (Read 18097 times)
Offline lucaerre
  • Unit(s): 898cx si - helix 10 si - solix 10 g2n si
« on: September 29, 2016, 02:04:30 PM »
Ho guys i'm Luca from italy. My 898c si have got the backlight broken and my warranty is over. I bought a 858c HD but It stop when i switch It on in the Humminbird screenshot . So is It possibile to put the led hd screen of the 858 to the 898c ?
Offline lucaerre
Re: 898c si CCFL to led upgrade?
« Reply #1 on: October 15, 2016, 07:35:23 AM »
Ok..nobody help me so i do it by myself. I open my device and i see that the lcd screen it's a Hitachi 7" lcd ccfl screen and you could fine It in Alibaba or aliexpress or lcd display seller sites at 350$ less or more . So i try now to open that lcd screen and try to repair the ccfl filament.
This is the model of the 898 cx si model :
Hitachi TX18D57VM2BAB
Offline navionic
« Reply #2 on: October 15, 2016, 10:10:38 AM »
Hello.
Out warranty repair Humminbird 898c - 340.45 $
Offline lucaerre
« Reply #3 on: October 15, 2016, 10:16:50 AM »
I don't wanna spend 300$ or more dollars because i'm sure that the trouble is only in the cold neon filament (ccfl) and i wanna try to changhe this neon so the repairing cost It Will be not more than 50 or 100$...and all' by myself.
Offline lucaerre
« Reply #4 on: October 15, 2016, 10:18:30 AM »
This is the ccfl lamp of the backlight schemes
« Reply #5 on: October 15, 2016, 12:32:59 PM »
Interesting ..... Hope you get it figured out.
Offline navionic
« Reply #6 on: October 16, 2016, 04:03:05 PM »
Check other functions. The problem may be not only in illumination.
Offline sonarbear
  • Unit(s): HB 898cxi SI HD
  • Software: na
  • Accessories: transom mount rod :-)
« Reply #7 on: November 07, 2016, 08:39:39 AM »
I didn't fully understand: your unit runs fine, except the screen stays dark? In this case, I'd recommend ripping the CCFL out and replacing it with a suitable strip of LEDs.
If the circuit is tested though, whether the lamp is on, the fix might be more involved.
If you want to use a different screen, make sure the controller is the same. Otherwise it might fry your unit.
Last post November 23, 2010, 01:05:40 PM
by Rorofr
Last post June 06, 2011, 09:44:51 AM
by ffmedic147
Last post March 01, 2013, 04:24:31 PM
Last post May 16, 2013, 06:15:26 PM
Last post August 03, 2013, 04:30:32 PM
Last post September 09, 2013, 04:48:17 PM
Last post May 05, 2014, 11:05:08 AM
Last post February 13, 2015, 09:34:51 PM
by gmintimidator
